Using 2 Cycle Oil in Diesel Fuel
Discussion in 'VP44 Pump' started by Mopar1973Man, Aug 27, 2011.
  1. ramhunter9
    ramhunter9 Supporting Member
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    Agreed but if ya got it use it. Thats my thought.
  2. Mopar1973Man
    Mopar1973Man Senior Member
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
    Ok... Use if for what?
    Keeping injectors clean? If so then you might be mildly surprised about the filter in the connector tube called a edge filter.. But that what a fuel filter is for keep debris out of the injectors.
    [​IMG]
    Quoted From Dodge's Factory Service Manual (2nd Gen VP44 and 3rd Gen CR)
    Each fuel injector connector tube contains an edge filter (Fig. 13) that breaks up small contaminants that enter the injector. The edge filter uses the injectors pulsating high-pressure to break up most particles so they are small enough to pass through the injector.
    So if its carbon build up you using the additive for you also be surprised you can soak it in any injector cleaner you wish and it will not remove anything. What cleans a injector nozzle its reaching 1,000*F EGT's and holding for several miles. Carbon burns at 1,000*F.
    So if its catane booster you already know that higher the cetane lower the BTU content. Might be a consideration for winter time start ups but that about all.
    If it lubricity... Well like you are finding out there isn't any major lubricant found in the MSDS sheets... As for AMSOil Diesel Con. it scored a 488 HFRR in the HFRR testing passing grade but low. And Bosch considers 450 HFRR border line...
    Something to think about...
  3. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    Dam you lol. I have 7 bottles. And the data shows the 2 stroke is better.
  4. MarbleCrusher
    MarbleCrusher Member
    73
    Aug 22, 2011
    North Texas
    Ram Year:
    2002
    Engine:
    VP Cummins
    Wow 7 bottles! Im sure that wasnt cheap either. Go grab some supertech and be safe happy and save on your wallet in the future.
    -Jordan-
  5. ramhunter9
    24,508
    885
    Jun 25, 2010
    Ram Year:
    Engine:
    Want some ? Lol
  6. dripley
    dripley Member
    75
    Aug 23, 2011
    hickory, nc
    Ram Year:
    2002 2500 ho 6 speed 4X4
    Engine:
    5.9 24v cummins
    I have been runnin it since installed my new vp about 15k ago. it even quiets the engine a little. every time i tow my rv i make sure i get the egt up above 1000 and hold it for a while to keep the injectors clean.
  7. MillsE45
    MillsE45 Junior Member
    Sep 24, 2016
    Ram Year:
    2007.5
    Engine:
    Cummins 6.7
    2007.5 dodge cummins
    I just bought a 2007.5 dodge cummins and it has 100horse injectors. Should I or shouldn't I run 2 stroke oil in it?
  8. Jimmy68
    Jimmy68 Senior Member
    1,402
    633
    Aug 30, 2015
    Lethbridge Alberta Canada
    Ram Year:
    2001
    Engine:
    5.2L Magnum
    Read first post again.
    How much 2 cycle oil to use?
    128:1 Ratio is fine for 12V and 24V Cummins trucks. On CR engines up to 07 you want to use 200:1 ratio. Beyond 07 don't use 2 cycle oil...
Share This Page
