- Jul 14, 2017
- 15
- 2
- Location
- Wherever the RV takes me
- 2017
- Hemi 5.7
Not sure if this is the correct sub forum or not. I looked in the Towing and Hauling forum, but didn't see any threads about a motor home towing the ram.
We have set up our Dodge Ram 1500 4x4 to be towed behind our Class A RV. I have Successfully set it up through the step by step directions about 6 or 7 times with no problem. Then the transmission or engine starting "chittering" 2 or 3 times when I would put it in drive near the end of the sequence to ensure the truck did not roll. I would start the entire sequence over again, and all would be fine. Yesterday it clicked or "chattered" a lot when I got to drive. Tried the sequence again, same thing. Decided not to take any chances and unhooked the toad, drove behind the motorhome. I DO READ the sequence each time, so as not to miss anything.
I do go through the sequence to move out of neutral every night when we stop and then the sequence to place back into neutral the next morning. Not sure if I need to do that every night since the truck is not in the accessory position as my Honda was.
Has anyone had this happen? Any ideas why it would happen?
