It has independent front suspension, not a live axle so it cannot be rolled and shifted forward. There are no radius arms.
Well then I am at a loss with out actually being there to look at the truck. Sorry.
This, this and this!!! Glad you got it solved. I finally found a local independent shop that makes me happy!I had a rear vibration issue , rotation did not work , " re-balance" did nothing , new tries and "balance also no joy . Today I went to my favorite Father and son garage had them do a balance took over an hour they found that most of the previous balances were no good and incompetent ., took the truck out for a test got her up to 110 zero vibration now .
I have been fighting the same symptoms for 8 months on my new 2017 RAM 1500 4x4. I added then removed a 3" leveling kit. It improved the ride but did nothing for the random vibration. I don't think it's tires or wheels. My vibration can be felt at any speed but is most noticeable at highway speeds. I had a loose left front drive axle. They fixed that. Also, my engine was missing. They fixed that. I've had several different shops and the dealership try different balancing and moving tires around. Symptoms don't change. That eliminates tires and wheels. We have suspended the truck multiple times and can't duplicate a vibration except for when the front axle shaft was loose. I also occasionally feel a grinding if I stop forward motion, put it in reverse and hit the gas a little quick. I think the problem is the limited slip differential. I constantly hear the back tires bark when I turn corners. I've always driven trucks with limited slip rear ends and never had my tires constantly bark like this one does. I now have a RAM care specialist that is supposed to contact the dealership as the truck is going back for a 5th trip. I will keep everyone posted.
