Water Stained Headliner
TMyers
USMC 84' - 92'
north wilkesboro, nc
Cummins 6.7
I just recently purchased a 2013 Ram 2500 Crew Cab. The truck has been cared for incredibly well. However, I did find one area that is bothering me. Water stains around the bottom of the third brake light in the headliner. Searching the web, I found that the brake light leak problem has been around for years.
Anyone know of a cleaning method?
MADDOG
Out Exploring Arizona
A lot of detailers have a steam cleaner they use for such things.
rwreuter
I recently had a similar issue....XM antenna leak. Sealed it up and then used and Blue Coral upholstery cleaner from Orielly's. Fixed it up.
rotwiler
Washington
2013 QC Outdoorsman
I noticed a faint water leak stain on my 2013 on passenger side, isn't too bad and I already installed a led blacked out 3rd brake light and added a better seal. But I was thinking of using some hydrogen peroxide in a spray bottle and mist the area. On my old class A RV, I had a bad leak, turned the ceiling in the spot almost black, the hydrogen peroxide totally removed the stain with no scrubbing.
Justin33
So I just noticed this on both sides in the back. My third break light is stock and the only other thing I can think of is the automatic wash I go and use. Now what are my options do I go to a detailer and have them steam it?
Justin33
Maybe this is my
Problem but I have it in the rear of quad cab on both sides.
Justin33
Would my third break light do it out of nowhere never had an issue till now assuming it’s the high pressure auto wash I have been using?
rwreuter
You could try and removing the 3rd brake light and resealing it. You have nothing to lose.
brad byron
Longs, S.C.
if you havent fixed the third breaklight problem, MOFORKIT makes a real good gasket to replace the original. search on amazon for it..............
16Longhorn
NWFL
I know this is an old post but I just went through this. I had a water leak from my sunroof and 3rd brake light. Both produced bad water stains on the headliner. The old guy (owner with 40+ yrs experience) that fixed a water leak from my sunroof told me the best thing he has found to remove water stains on the headliner is Febreze. Yes the air freshener. He said to just spray it on the headliner and scrub with a cloth until it's gone/clean. He showed me and sure enough Febreze Air Freshener got it clean like new. Added bonus was it smelt better in the cab also.
ramffml
ramforum
Gotta admit, that febreze has a certain something to it, like catnip for humans!
Treburkulosis
Your High End Detailer
Haslet, TX
Steam clean it is the most effective way. I actually have a small area on mine that I need to address. Give me a couple of hours and I will try something that I have at home and see if it works. On super dirty vehicles I bust this thing out with Shine Supply Solution. Ill try just solution by itself in a little bit and report back.
Treburkulosis
Haslet, TX
So I just did solution and a microfiber towel. It appears to have worked, but I may need to spot treat it again with Shine Supply Fabric RX. I am taking pictures. Let it dry for a few hours and I will give a full update.
shrubs
Nolensville, TN
First off seal/stop the problem . The gasket on AMZ could be a player or the attach. Your decision.
Cleaning. I suspect to try simple to complex. I.e. rubbing with vinegar, Febreeze etc. up to steam cleaning or paying a detailer.
Our 2015 needed a bulb, we luckily replaced it with OEM parts already on. Watched for leaks. We had none.
Treburkulosis
Haslet, TX
So to update sorry it took a bit. Shine Supply Solution cleaned mine right up. They were dark brown stained.
shrubs
Nolensville, TN
Can I clean my tile grout with this? I might be in the "and much more" category.:)
SIMPLIFY YOUR CLEANING.
Solution is an advanced multi-purpose cleanser that will clean anything it touches. Its pH balanced formula delivers safe and effective results on nearly any surface. Solution can do this because it works by emulsification. This means that instead of “burning” off grime, which is ineffective and unsafe, it actually “loosens” the soiled area ensuring successful results.
Solution is safe and effective on:
leather
vinyl
plastics
tires
wheels
undercarriage
engines
paint
AND MUCH MORE
Dilute Solution with water according to what task your'e performing.
10:1 for light interior cleaning, leather and exterior paint prep.
4:1 for heavy cleaning on vinyl, and plastics.
1:1 for heavy duty cleaning, undercarriage and motor cleaning
Treburkulosis
Haslet, TX
Solution is one of my favorite products for heavy soiled stuff. If its not that bad, then Totally Awesome is my go to there. If I am in a time crunch I will bust out Koch Chemie ASC. It is just not that cost effective.
