What did you do to/with your second gen today?
Discussion in 'General Discussion' started by Johnn123, Sep 29, 2013.
  1. Shadow_Death
    Shadow_Death Senior Member
    169
    12
    Feb 13, 2017
    Ram Year:
    1996
    Engine:
    5.2L Magnum
    Dropped the transmission pan changed the filter and adjusted the bands. She shifts like a damn catallac now. Let me tell you guys one thing though. Whoever decided to use a 6 sided almost square bolt for the rear band is on my shit list now. Nobody near me sells a 5/16 4 point socket. Luckily I did some whick Google Fu and there was a thread in the Durango forums that mentioned using a 5/16 8 point socket. So I want to Lowe's and picked one up. It worked beautifully! But seriously... That one engineer....... I hope he stepped on a Lego or two at night.
    Update 2/11/2018: 1 to 2 quarts my ass. XD I've put in 5-6 quarts because the TC drained while I changed the filter and fluid.
  2. dodge dude94
    dodge dude94 Senior Member
    23
    27,481
    6,271
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    Was supposed to haul a 00 Ram home to work on for our friends. Got to their house where the truck was and it was in even worse shape than I imagined.
    Had issues getting it on the trailer, gashed a tire and broke a trailer light. Called it a day at that. That truck is going on the back burner for them and I will be repairing it where it sits when they decide to fix it.
    So I hauled an 18ft flat bed all half the day for nothing. :roflsquared:
  3. jlbayes
    jlbayes Senior Member
    164
    14
    Aug 3, 2017
    Ram Year:
    2001 & 1997
    Engine:
    5.9l cummins
    New door components and cluster leds.
  4. Shadow_Death
    169
    12
    Feb 13, 2017
    Ram Year:
    1996
    Engine:
    5.2L Magnum
    A trick most guys I work with do is to unbolt the bed and tilt it to the passenger side and work that way. Our motto is why drop a full tank when you can lift an empty bed? Fuel pumps never go out when the tank is empty that much is for sure.
  5. dapepper9
    dapepper9 Senior Member
    22
    4,873
    1,873
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    I recently fabbed up some tailpipes and mounts to get rid of the axle dump setup. 45s under the bumper corners, plain, unfinished, no tips. Looks fine to me, killed what little drone i had and sounds better under throttle.
    Today i finally installed my BD Diesel 3rd gen conversion track bar. Kind of a bitch when it's like 10 degrees out and snowy. Froze my butt off but she's solid. Needs aligned but it's adjustable too so I'm not too worried about it. Currently bolted up the way knockoffs do it, need to add the side brace bolts but i messed up 1 drill hole and didn't have the right wrench anyways. So screw it ill do it Wednesday when it's 40 outside.
    Also ran an 8.550 0-60 today. Not bad for 34" tires, a bed full of junk and a 214.5k bottom end lol
    dodge dude94 likes this.
  6. Shadow_Death
    169
    12
    Feb 13, 2017
    Ram Year:
    1996
    Engine:
    5.2L Magnum
    Just finished rewiring my headlights. Now they are properly relayed and both the 9004 and 9007 high beams come on with highs but only 9007 lows come on with lows.
Share This Page
