What did you do to your Gen3 today?
Discussion in 'General Discussions' started by SmokedRam, May 27, 2012.
  1. chrisp2493
    chrisp2493 Always Modding
    24
    2,265
    1,164
    Oct 30, 2016
    Warren, OH
    Ram Year:
    2003
    Engine:
    392 Hemi
    I highly doubt you are losing oil from the gasket, unless you got a puddle under where the truck is parked. Sounds like you got a bigger issue. And you are gonna have a heck of a time replacing that gasket, it’s hard enough getting the oil pan separated from the engine block when it’s on a stand, let alone in the truck. You are gonna be wasting a lot of your time. You’ll probably be able to tell once you start replacing spark plugs. Look for ones that are fouled up to see where your oil is blowing by
    I Bleed Ram Trucks
    Ron Morell and Purplert like this.
  2. Drunken Hamster
    Drunken Hamster Damn Skippy!
    20
    1,418
    259
    Jul 18, 2017
    Tampa, Florida
    Ram Year:
    2005
    Engine:
    Are you saying that it might need a rebuild? Because it was using half a quart every 2k, but at the same time, most of the last oci was left unchecked until the last 1/3 or 1/4 of the 7k it was in there, and when it did finally get checked consistently, it never went below the safe zone.
    I've never seen an oil puddle caused by my truck, nor have I seen the typical rainbow water in my driveway...
    (It seems like it loses what it deems as "excess" oil and then holds steady from there? Also, side note, Redline has given me cold/startup tick that -as far as I can remember- I never had, while eliminating the slight warm tick I did have. Then again, with the mani leak, the guys in the syn thread say I can't really know until I fix that...)
    Perhaps it's something less severe like the pcv valve. In which case, I already have a replacement and plan on doing that with the plugs.
    Got a pic of what I should be looking for?
    Sent from my magic 5-inch
  3. ST-8
    ST-8 Senior Member
    2,135
    724
    Mar 26, 2013
    Ram Year:
    Engine:
    Look for oil, usually how I start tracking stuff like that in truck
    ramportin1 and Jerseystyle like this.
  4. Jerseystyle
    Jerseystyle Senior Member
    443
    181
    Feb 11, 2017
    Ram Year:
    Engine:
    4.7
    Got'em!
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    02ramboi likes this.
  5. Demon-HeMi
    Demon-HeMi Super Moderator Staff Member
    3,660
    2,424
    Dec 30, 2010
    Houston
    Ram Year:
    2003, 2003, 2008, & 2013
    Engine:
    (2) 5.7 HEMI, 3.7, & 3.6
    with tow mirrors you arent supposed to see the side of the truck in the big mirror, the big mirror shows you what it needs to and if you need to see your truck for proximity purpose thats what the blind spot mirrors do
  6. Demon-HeMi
    3,660
    2,424
    Dec 30, 2010
    Houston
    Ram Year:
    Engine:
    Had to find a pic of my 3g tow mirrors on my truck, but here you can see, the main mirror shows you whats behind you, and the blind spot shows you your truck, where you are in the lane, and everything in your blind spot
    [​IMG]
    Basically the big mirror looks straight back and slightly away from your truck (down the lane next to you, so you can see everything better, including the trailer, my joke i tell everyone is i can see behind the car behind me to help me watch for cops...
    but folded down they are like any other mirror
  7. Demon-HeMi
    3,660
    2,424
    Dec 30, 2010
    Houston
    Ram Year:
    Engine:
    Hell even my drivers side you can barely see the actual body of the truck...
    [​IMG]
    But thats how tow mirrors work, they dont have that "closer than they appear" message, they are just a good mirror for showing you around your trailer, and what others are doing behind you, rest of the stuff is covered by blind spot mirrors
    xtremewlr likes this.
  8. cliftonclendenen
    cliftonclendenen Senior Member
    228
    147
    Jul 16, 2017
    York, Pennsylvania
    Ram Year:
    2006
    Engine:
    4.7L V8
    I’m thinking about color matching my interior fake wood trim pieces as well when my paint shows up. Is there any way to remove them, they look like they are plastic welded in.
    [​IMG]
    I’m thinking of heating them up and bending the plastic up so it can release, or would it just be easier to just mask the door panel?
  9. chrisp2493
    24
    2,265
    1,164
    Oct 30, 2016
    Warren, OH
    Ram Year:
    2003
    Engine:
    392 Hemi
    I’d say just mask the door panel. You could probably melt or drill out the little spot welds there and jb weld them back in, just a lot of extra work
    I Bleed Ram Trucks
    cliftonclendenen likes this.
  10. Demon-HeMi
    3,660
    2,424
    Dec 30, 2010
    Houston
    Ram Year:
    Engine:
    I so want the laramie panels for the 02-05 interior so i can do just that to my show truck...
    ultimately to remove them you would have to drill out those tabs and then plastic weld them back in when done, but if your taping skills are good then just tape em off and have at it
Share This Page
