what end links?
AJMAG
new jersey
my 04.5 cummins needs new end links and not sure which ones to look at? someone enlighten me. its got a 4.5 inch lift
HemiBabe
DFW
It looks like those may work... do you want to do an OEM replacement or upgrade?
AJMAG
AJMAG
new jersey
whatever works lol i picked up some moog links on amazon for now since i got them for $40 shipped :waytogo: may upgrade eventually though i needed them in a hury so i just grabbed them
Stangshcky12
Oshkosh, WI
5.9 Cummins
Do you have a sway bar drop or did the kit come with longer links?
Hammer_Z71
It appears those Hell Bents are stock length and they want you to buy their drop brackets for lifted applications.
You want enough length on them to keep the sway bar at stock level, which is pretty much parallel to the ground. A sway bar becomes pretty much useless at over 20% of stock angle.
Now here's what I did on my Grand Cherokee when I lifted it 3". The only brand of extended lengths I could fine were $150 for the set, so I bought a set of new stockers off ebay for $22, cut and welded a solid piece of steel in the middle of them, 2 3/4" long which is what I measured I would need to keep the rear sway bar parallel to the ground.
Worked out quite well and saved me some serious coinage...
after they cooled off, I just hit 'em with some black rustoleum and on the Jeep they went...
man n black
Cummins
You could probably make your own adjustable ones using rod ends and threaded rod too!
Ch
Sent from my DROID RAZR
