What kind of whacky AC/Heat issue is this?
JohnRBurke2
Detroit, mi.
5.2 V8 Magnum
Hi have a 2001 Dodge Ram 1500 sport.
I have dealt with this for the last year or so but want to fix it now.
ISSUES:
1) My AC does not work. The fan blows strong but only heat, even when AC is selected.
2) My heat does not turn off. It is always on and blows harder when I accelerate aggressively.
3) The fan only blows from the floor and defrost, not from the dash.
4) I burn through coolant really quickly. There is no leaking. It just evaporates or something. I can smell it at times when running a full reservoir.
Help super heroes of the ram forums.
dapepper9
Iowa/Nebraska Border
5.9L V8
Heater core has a pinhole leak. That's where your coolant is going.
Heat thing sounds like a vacuum leak and blend door failure. What sucks is more than likely this is inside the dash. Less ****** part is you'll be in there anyways to do the heater core lol
KarL45
Western Slope, Colorado
2018 Ram Express quad cab 4x4
5.7 MDS
I would guess there is more than one problem. Low vacuum (hard accell) will equate to the default setting of defrost as well as a vacuum leak. As for leakage, heater core or even possible head gasket? Good luck and let us know what you find.
MADDOG
Not RamForum Staff
^^^ This ^^^
