richman513
- May 15, 2017
- 25
- 8
- 2014
- 6.7
Those body mounts are stock.Is this a body lift or is this how it looks stock? Thanks for the help
Sent from my SM-G950U using Tapatalk
Thank you for the reply. I definitely need new bushings all around. I will update when I'm done. I'm going to do new bushings all around.The 08.5+ steering will make a big difference for you. You will probably need a new steering stabilizer setup with the new linkage. Also might consider freshening up the bushings on your track bar as well (or replace with an adjustable). That all cleaned up my wander almost completely.
Where did you source the new steering? Is there a write up somewhere?The 08.5+ steering will make a big difference for you. You will probably need a new steering stabilizer setup with the new linkage. Also might consider freshening up the bushings on your track bar as well (or replace with an adjustable). That all cleaned up my wander almost completely.
