Yoox_II
- May 26, 2013
- 300
- 26
- 1984
- 5.7L Hemi
I'll give you guys a play by play of what happened today.
I left the key turned on to listen to the radio today and forgot too turn it off.
I went back a couple hours later and it was dead, obviously.
I got jump started by a guy I work with, the truck started up fine and I kept it revved up as best I could to keep it from stalling, just In case.
About 10 minutes into the drive home it started losing power and then chugged to a stall.
I got boosted again and it started again
Same thing happened, it chugged to a stall except this time, it literally sounded like it was running on 1 or 2 cylinders. It sounded identical to a go kart.
Got boosted a third time and it started, but then chugged to a stall once again, but also back fired and puffed out a massive cloud of grey smoke.
Now, it can start only if I get boosted, but it will only stay running for a kilometer or two then the backfire and stall and smoke happens again.
SO is this related to my battery dying? It seems like these problems are unrelated... I hope it is not a timing belt problem. the "one cylinder" sound really worries me. Why would some of my cylinders and pistons disengage?
Thanks guys
PS: even if I let it idle, instead of driving, it stalls after about 30 seconds even if I am keeping the revs up fairly high
Thanks guys
