Wheel size for 2500
jguida
Hey guys, I tried searching and didn't see what I was looking for.. if it's already out there just point me in the right direction please. I got a (new to me) 2015 2500 with 4.10 axle for work and towing my camper and have been looking into tires/wheels. My question relates to wheel size. My ram has factory 20" wheels. Would going down to 18" improve the ride/towing or should I just stick with the 20s? I'm also looking to have a winter set along with my summer set, any preference for wheel size during winter driving? Appreciated.
Ratket
Arizona-
18”s would give you more side wall, wich would mean a little softer when towing as it will flex a little more.
Everyone has different opinions for winter/summer tires,
If u want different tires for winter, find a set of 2500 take off rims for a reasonable price and just have the winter tires mounted to them.
Gratz on the new truck!!!
14RAM4X4
Sweating somewhere in South Texas
2015 RAM 2500 4x4
6.4L Hemi
Like Ratket touched on.
18 will give you a better ride, but a little softer when towing. So it's a +/-
You can also stay with a 20" wheel and lower the tire pressure to 50 psi. I'm running 50 psi front & rear. Ran that on both 295/65r20s & my current 37x12.50s.
I'd say 18s will be good. Unless you're towing / hauling really heavy, they should be good with tires about stock height. To be honest, on 37s at 55 psi the tires barely buldge when I had a yard of topsoil in the back.
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
OP, will correct me if I'm wrong but i believe the price of 18" tires will be quite a bit less that the corresponding tire size in a 20" wheel. I also personally like more meat on my wheels over the lower profile tires, especially on 4x4 trucks. This looks damn good IMO.
18" wheel wrapped in a 295/70/18. Stock ride height. And I'm a pic *****.
RainDesert
ID
Has anyone run aftermarket 17's on a newer Ram? I know on Ford it is a very tight fit but I like some of the 17" tires/sizes.
14RAM4X4
2015 RAM 2500 4x4
6.4L Hemi
17's should fit. AEV has 17" wheels for Ram HD trucks. AEV is known for their high quality (and corresponding high price) and lots of time in R&D on their products. They have wheels in both a 17x8.5 +27mm & 17x10 -15mm. If I was in the market for new tires and had the extra jack for wheels, I'd love to go with some of their Katla wheels !
5.7L Hemi 2500
I run aftermarket blackrock steel 17's on my 2012, they fit with plenty of room for the calipers. 17" wheels have a much better tire selection than 18's as well.
J
jguida
Yeah, that's a solid look. I'm not overly fond of how the 20's look or feel so I'm appreciating a bit of confirmation. 18" tires are definitely a bit cheaper, I just need to find some wheels now.
Blue Streak
Southern Oregon
2017 POWER WAGON & 1979 W150
6.4L HEMI & 440 Wedge
17"s work just fine! Ran them on my '12 3500 with no problems. My Power Wagon came with 17"s and I will stick with that size when I swap out for aftermarket.
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
18s or 17s with a bigger meat will def improve the ride for you.
RainDesert
ID
What is the factory Power Wagon size?
King nothing
Central IL
Cummins
Those wheels look great. And the tire size is awesome too. I’m looking at either 285/75/18s or 295/70/18s
