bozeblake
- Jan 1, 2017
- 59
- 6
- 1987
- 318
What is the best way to remove wiper motor?
Sent from my XT1585 using Tapatalk
I think I hooked up a ground wrong and when I turned key a puff of smoke came out and now it want workwith ratcheting wrenches lol. in all seriousness if you do have ratcheting wrenches it will likely make the job easier. you have to remove the cowl to disconnected the motor from the linkage and then just remove the 3 bolts that hold the motor to the body. are you having issues with it. only reason i ask is dodges are known for poor ground connections to the wiper motors
Thanks, I am going to pull off Sunday.it is pretty hard to mess up hooking up a ground to it. if you saw a puff of smoke something likely went bad inside. there is only the 1 nut and 3 bolts that hold the motor to the body. it can be a time consuming job especially without the ratcheting wrenches but not too bad.
Ok that came off pretty easy. Thanks, but I can not get wiper arms offit is pretty hard to mess up hooking up a ground to it. if you saw a puff of smoke something likely went bad inside. there is only the 1 nut and 3 bolts that hold the motor to the body. it can be a time consuming job especially without the ratcheting wrenches but not too bad.
