wire identification help
Discussion in 'Audio & Electronics' started by IJW84, Nov 2, 2016.
  1. IJW84
    IJW84 Member
    30
    Feb 19, 2016
    Ram Year:
    2008
    Engine:
    I am changing the front door speakers in my truck ('08 1500) and need to know which wires are + and -
    both the wires are green, one has a blue strip and the other is a yellow strip.
    nothing else in the old speakers indicates which is which.
    thx
  2. Bullitt5339
    Bullitt5339 Senior Member
    920
    507
    Jul 5, 2015
    St Pauls, NC
    Ram Year:
    Engine:
    3.7
    LF Speaker +: Dark Green/Yellow
    LF Speaker -: Dark Green/Light Blue
    RF Speaker +: Gray/yellow
    RF Speaker -: Gray/Light Blue
    LR Speaker +: Gray/Light Green
    LR Speaker -: Gray/Dark Green
    RR Speaker +: Dark Green/Light Green
    RR Speaker -: Dark Green/Gray
  3. IJW84
    IJW84 Member
    30
    Feb 19, 2016
    Ram Year:
    2008
    Engine:
    right on...thank u very much
  4. justin13703
    justin13703 Senior Member
    28
    1,006
    296
    Oct 15, 2014
    MD
    Ram Year:
    2008
    Engine:
    Keep in mind that you can buy plug in speaker harnesses for around 12 dollars for all 4 that will keep you from having to cut/splice the factory wiring. They also help prevent corrosion on the cut/spliced area of the wire over years in the environment of the inside of a door panel.
  5. TerrorByteFX
    TerrorByteFX Junior Member
    38
    18
    Jul 20, 2013
    Ram Year:
    2008
    Engine:
    V8 4.7 Liter FlexFuel
Share This Page
