I just bought the https://www.autoanything.com/nerf-bars/westin-molded-running-boards-with-mount-kit for my 17 Dodge Ram 1500 Quad cab. I figured there would be some direction for how to run the electrical.
Determine whether your vehicle has a positive or negative switching courtesy system or an auxiliary light source (most Fords). Obtain an accurate wiring diagram for your vehicle's courtesy light system.
For positive and negative switching:
Locate a pass-through point (usually under carpet at driver side door sill) for the wire harness. Locate main courtesy wire (usually wire lead to dome
light). NOTE: If you do not use the main courtesy wire, lights will only function when one door is open. Route wire harness so that the 2 female
connections (from step board) are nearest to pass thru point.*Connect opposite step board lead to either connection. Connect the splicing lead to
remaining female socket and route one wire thru pass thru point.
VERY IMPORTANT - Double check that your system has positive or negative switching.
For positive switching only: Connect positive wire to main courtesy system, (usually wire lead to dome light). TEST CONTINUITY BEFORE
CONNECTING BY OPENING AND CLOSING ALL DOORS. Ground remaining wire.
For negative switching only: Connect negative wire to main courtesy system, (usually wire lead to dome light but sometimes from dome light to
courtesy ECU). TEST GROUND CONTINUITY BEFORE CONNECTING BY OPENING AND CLOSING ALL DOORS. Connect remaining wire to battery using
a 5A fuse.
**Be sure that you have not routed any wires near moving parts (i.e.. driveshaft) or near any heat generating source (i.e.. transmission, engine,
exhaust).
Auxiliary Light source:
Locate auxiliary light source connection under vehicle (usually attached to back side of front or rear fender well (refer to vehicles owners manual).
SEE FIGURE 12. TEST SOURCE BEFORE CONNECTING. Connect splicing leads to aux light source. test step board lights for proper
function by opening and closing doors.
