Wiring Question
Discussion in 'Tech Info' started by 2014_Sick7, Dec 30, 2016.
  1. 2014_Sick7
    2014_Sick7 Junior Member
    Dec 30, 2016
    Ram Year:
    Engine:
    Cummins 6.7
    I recently bought a light bar for my front bumper and it comes with a harness and I understand how it works, but where will I need to run my switch/button to get it in the cab? Its a little switch about the size of your thumb, it may be a simple answer, but just want to make sure I know what im doing before I start!
  2. R.L.K.
    R.L.K. Supporting Member
    10,214
    6,071
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    I would run it through the Unused plastic clutch cover plate . It's located on the firewall above the gas pedal area .
    You can drill it in place , or remove it , just two screws if I remember correctly.
    I ran my Backup camera wires through this . I drilled a 3/4 " hole and installed a rubber grommet.
  3. R.L.K.
    10,214
    6,071
    Dec 1, 2013
    Bristol , Tn.
    Ram Year:
    Engine:
    You can also go through the rubber boot where the main harness comes into the cabin , just below the brake reservoir. There's an unused nipple on the bottom of the boot ment to run wires in the cab , you may have to cut it open , mine didn't have anything running through it , I didn't want to cut it so I opted to drill & grommet the clutch plate .
    Hope this helps .
  4. 12sportmc
    12sportmc Senior Member
    33
    803
    346
    Oct 21, 2016
    NC
    Ram Year:
    Engine:
    The grommet R.I.K. Is referring to is held in by 2 15mm nuts on the inside of the cab right above the brake pedal. Super easy to take out and drill a hole into. Alternately you can cut the unused nipple off the factory wiring grommet and use that. I used that one for my kicker sub install but the grommet for my remote start and power fold mirrors
    R.L.K. likes this.
  5. 2014_Sick7
    Dec 30, 2016
    Ram Year:
    Engine:
    Cummins 6.7
    I'll look at it tomorrow, thanks!
  6. Ferro
    Ferro Senior Member
    435
    192
    Sep 17, 2016
    Ram Year:
    Engine:
    I went through the plastic clutch cover. This is where I ran the switch. Very neat and clean but easy to access. I don't like drill holes in The dash.
  7. hankRam2015
    hankRam2015 Senior Member
    1,009
    305
    Aug 17, 2015
    Ram Year:
    Engine:
    Nice. That looks like it supposed to be there. Turned out nice bud
Share This Page
