Won't Start
Ramst
5.9l V8 Magnum
2000 1500 5.9l V8 Magnum
I have a good battery, good relay, and good start motor. Lights and radio will come on.
Lights won't dim when I try to turn on the engine, and the internet said that's a faulty starter - I now have a new starter. My battery was 3 years old - I now have a new battery. I substituted other relays for the starter relay, but it won't turn on.
I hear a single click, and no crank. Next up I'll start replacing the ignition switch, followed by the wiring... but if anyone could point me in the right direction so I don't fix what is not broken, I would appreciate you.
Help! Thanks!
duane9586
8.0L V10
Check your grounds and make sure they are clean. Mine did the same thing and it was a fuse in the fuse panel under the hood
R
Ramst
5.9l V8 Magnum
Still good... I get everything I need.. minus the engine. Thanks fokr the reply.
