jdelliott
- Nov 13, 2014
- 2
- 0
- 2001 1500
- 5.9 Magnum
Hey guys, new member here. This may be a little long, but I want to make sure that all info is given so that maybe we can get this truck running right, and from experience with other forums, a lot of members just say "HALP!!! It wont work" and expect you to figure out that they are out of blinker fluid. LOL
Anyway, the tl;dr version for those that are impatient: timing gear broke on my FIL's '01 1500 5.9L, replaced it, now it won't stay running. It does what is depicted in the video:
Dodge ram won't stay running after timing chain sw - YouTube
Now the long version:
My father in law and his next door neighbor replaced his water pump on his 2001 Ram 1500 5.9L due to bearing noise and seepage from the weep hole. After they replaced it, he went to go start it up, heard a sound that he described as nuts in a tin can, and would not even try to fire up.
I was called, and came over to inspect. Checked for spark, nothing. Did research, and he replaced the cam sensor in the distributor because that is the code that was being thrown. Replaced coil, and still nothing.
I got to thinking about it, and had him crank the engine with the cap off. Rotor did not move, and that gave me my answer: something wrong with the timing chain.
Pulled the water pump back off, AC compressor, alternator, power steering pump, and then the timing cover, and we were greeted with a cam gear shattered in four pieces. That explained the nuts in a tin can sound.
Bought the new timing set. I have replaced timing belts and chains before, but never after they have broken. I am more proactive than that with my vehicles.
So, I am basing what I am doing off of my knowledge of what should happen and when inside the engine while I am replacing it. Dots on the gears facing each other, straight up and down, from my research rotor bug at about the 1 o'clock position. I put my cylinder leak down tester on #1 cylinder, and was getting ~15% loss, which is acceptable according to the instructions that came with it.
Below is a picture of the timing marks as we had them aligned. If you cannot see the picture, let me know how to fix it, please.
Put it all back together, new oil, coolant, thermostat while we are there, spark plugs, distributor cap and rotor, and coil. Anti-seize on the plugs, dielectric grease on the wires
Go to fire it up, and it will start, but you have to keep your foot on the gas in order for it to stay running, and putting it in drive and moving it is out of the question.
Checked the spark plug wires against an online firing order diagram, and #2 and #4 were accidentally swapped, so put them where they go. Still the same result, runs like crap.
I took this video after everything listed above was done, and I am hoping someone here can help me figure out what is wrong.
Thank you very much for you time and expertise. Like I said above, I have never done this when the crank and cam have been rotated in relation to each other, but I know the general principles of how to put it right, and I am afraid I missed something.
John Elliott
John Elliott
