WTB: blacked out fog lights vertical
Status
Not open for further replies.
Dustin Steffey
Fernley, NV
Looking for replacement fog lights for a big horn 2017 ram vertical fogs....let me know and thank you. Some ideas were pods but can’t find a vertical bracket or morimoto, but not quite sold on them
RedFalcon
Katy, TX
I have a set of regular vertical fog light housings off my 2013 express. They aren't blacked out, just factory.
Dustin Steffey
Dustin Steffey
Fernley, NV
Thank you my friend that is what I have now currently I want to replace
RedFalcon
Katy, TX
Sorry, I misunderstood then. I did the pod route on mine and used ICI mounting bracket, but I know Altered Off Road has a set of brackets as well
Dustin Steffey
Dustin Steffey
Fernley, NV
Red falcon I’m interested in what you did tell me more and if I would be able to do it on my bumper, I have attached a pic
RedFalcon
Katy, TX
No reason why you shouldn't be able to do the same. All I did was unbolt the old housing and then put two 2x2 pods on each bracket which then bolted into the factory spot. And I wired to pods to a female 9006 connector for both sides and it plugs straight into the factory wiring.
Dustin Steffey
Dustin Steffey
Fernley, NV
That is what I’m looking for!!! What pods are you using and what bracket? Thanks for all the info
RedFalcon
Katy, TX
ICI used to make brackets for the 2013+ 1500's with the vertical fog lights, but I can't find them for some reason. The one I'm using is the SideTracked Off Road bracket which is about $50. I had a spare set of 2x2 fog light pods from ebay from when I bought my lightbar and backup pods, so I just grabbed a 9006 female connector and wired up my own harness that would plug into the factory wiring.
Dustin Steffey
Dustin Steffey
Fernley, NV
So there is the issue I can’t find brackets for the vertical fogs
RedFalcon
Katy, TX
It looks like Side Tracked Off Road still sells their bracket according to the product listing on their website
Status
radikio
