Zone install pictures with questions
Discussion in 'Lifted' started by EvoNiner1986, Jan 8, 2017.
  1. EvoNiner1986
    EvoNiner1986 Member
    31
    52
    18
    Sep 20, 2016
    Ram Year:
    Engine:
    3.0
    Had my Zone lift installed on my EcoDiesel and took pictures on something I wanted to make sure was done correctly. Input appreciated
    You can see how the 'mount' or whatever it's called on driver side looks like it was cut, and the passenger side wasn't (2 full holes on that one). Just want to make sure this was done correctly, thanks!!
  2. Solid State
    Solid State Senior Member
    520
    199
    Apr 18, 2016
    Ram Year:
    2011 Bighorn
    Engine:
    The crossmember needs to be cut on the drivers side to clear the front difrerential.
  3. Drummin4jc
    Drummin4jc Senior Member
    2,169
    869
    Feb 3, 2015
    SW Pennsylvania
    Ram Year:
    2012 RAM 1500 Express QC
    Engine:
    Looks good to me. Like Solid State said, you do need to cut the stock crossmember in order to allow the drop of the differential.
    Adam
  4. 6.7CumminsDrvr
    6.7CumminsDrvr Senior Member
    1,086
    406
    Dec 6, 2011
    Georgia
    Ram Year:
    Engine:
    Looks good to me. I have a different brand but mine was only trimmed on one side aswell.
  5. brandonjansen
    brandonjansen Senior Member
    1,689
    901
    Feb 14, 2013
    Abbotsford, BC, Canada
    Ram Year:
    2012 Ram 3500 Laramie Limited
    Engine:
    As the others have stated, yes that's done correctly. Any proper lift kit that comes with a front differential drop brackets requires that OEM crossmember mount to be cut off to provide the clearance for the front diff to drop down.
  6. 57buick
    57buick Senior Member
    171
    63
    May 2, 2015
    Salem, OR
    Ram Year:
    Engine:
    6.7L diesel
    What model truck and which lift? I installed a Zone 6" lift on my 2015 2500 diesel and I didn't do any cutting?
  7. brandonjansen
    1,689
    901
    Feb 14, 2013
    Ram Year:
    Engine:
    1500's require the cutting. 2500/3500's have a completely different front suspension and therefore different requirements.
    Drummin4jc likes this.
Share This Page
