water in rear cab
ClarkR
Crawfordville, Florida
Quick and inexpensive way to stop failing cab vents from leaking water and stop leaves, small branches from going between your rear cab and front box.
Clean all the debris from the flashing at the bottom of your rear cab and front box. It also has the added bonus of limiting or completely stopping water from entering the rear seat under the storage area because of faulty cab vent.
Get 1 piece of foam pipe insulation, non split. Cut it to 66 inches long, 3/4 ID. Use krylon spray paint if you're worried of it standing out too much. Make sure to let it completely dry before installing.
When ready, stand in the box head towards the rear of the cab. Start firmly but not aggressively pushing the sleeve into the void till most is inserted. Make sure to not push too hard or far or it will fall into the recess of the box lip. Remember to center it before stuffing it as it becomes progressively difficult when moving down.
It worked like a charm for my 2015 RAM Big Horn, enjoy
heefageLA
Vidalia, LA
05, 14, 17, 20, 23
Also check your sliding window seals and 3rd break light seals.
Ill be changing out my third brake light seal this weekend when I install LEDs up there. Ive done it to the last 2 trucks I had and never had an issue. The factory seal is junk. Its basically foam that deteriorates over time.
Justin33
This actually make sense but I’d have to see what you did.
ClarkR
ClarkR
Nothing to see really, rubberized electrical taped 2 together, cut to length and cleaned the area, stuffing in down as to not go past the top lip of the box defeating the tight fit. Stays in place, during all driving, washes, etc.
No, i took the bed off to paint the whole truck
Look on YouTube, there are several ways to change out the vents.
First step is to remove the rear seat
type this into your laptop search engine
2016 Ram 1500 replace leaking cab vents
Justin33
I get it now I thought you had taken that and then cut it to block the can vents so water couldn’t get in.
Sundown
