Radio Fuse?
Richard1075
San Antonio, Texas
Pentastar 3.6L
Anybody know which numbered location in the fuse box is for a 8.4A radio in a 2014 1500 CC truck? I've looked at the Owner's manual but the only thing it lists is location F55 for a E38 radio (if equipped). There's no fuse in my F55 location.
Richard1075
Richard1075
San Antonio, Texas
Pentastar 3.6L
I want to kill the power to the radio for a while because my AM radio has stopped working, and I read on here that will reset the radio and possible fix problems with it.
Ramzaq
Northern California
2009 CC 4X4 3.55 Big Horn
Just lift your hood, a plastic box in front of the battery is your fuse box, open it up and you will see all the fuses. The reference for the fuse locations will be on top of the box when you open it.
On the 2009 it is #38 and it is a green 30 amp fuse, not sure if it is the same on 2014.
Richard1075
Richard1075
San Antonio, Texas
Pentastar 3.6L
Thanks, I'm familiar with the fuse box location, that's how I knew F55 was empty. F38 is the Power Inverter on a 2014.
Anyone else?
Go Spurs Go!
NewbieRam
3.6L
2014 Radio Fuse
Found the little bugger...it is on the harness, not in box. Look toward the back and below the top of the battery. There is a holder there with a 20 Amp fuse. PS have your theft code ready.
nogovitsin
Thanks a lot for your input! I thought i burned my stereo!:favorites13:
