Tires and Rims
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Any of you guys have 18"s on 33"s or 20"s on 33"s?
If you do, please post up some pics and include size of rim (like 18x9) and the size of the tire as well as the make/model of tire.
Thanks guys!!
MADDOG
Out Exploring Arizona
Is your set up stock right now?
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
You gonna put the 2.5" on before?
Btw, it's a lot cheaper to buy wider 16's, plus the tires are cheaper too. but I think I'm partial to a good amount of sidewall though lol
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I have some new, nice black/chrome highlight rims that are 16x8 on new 285/75/16 MT'S but 16"s are too small for me(probably sell for about $1200 because both only have 3000 miles on them).
I'm putting a 2.5" spacer up front but leaving the rear stock so biggest tire I can fit is about a 33.5-34 because the rear is the limiting factor because I want the front end higher
metric sizes I'm looking for is
275/70/18
285/70/18
305/65/18
275/60/20
285/60/20
305/55/20
Or..
33x12.5x18
33x12.5x20
Or any other size close to those. I just want to see some 18"s and 20"s on our 2nd Gens to see if I want 18s or 20s
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Looked at tires in person and leaning more toward 20"s
But concerned that 275/60r20 (33x10.8x20) will not have enough tire to it to protect my rims from the mild offroading I do. What your thoughts?
Merc225hp
NA
truck
gas
16 or 17 that my choice nothing bigger for a rim than those two. Step down to a 18 then.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
some numbers:
Side wall on 20"s is about 6.5"
side wall on 18"s is about 7.5"
6.5" is the thuging look? I've also though 20"s as of the I have money and don't cut corners by spray painting my rims :confused::rofl:
dapepper9
Iowa/Nebraska Border
5.9L V8
some numbers:
Not necessarily i was just refreferring to how as wheels start to go over 20" it tends to be more of the guys that think they're gangsters putting them on lol
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I agree! I think you need at least 5-6" of side wall On the tire/rim setup
99RoughCountryRam
Northeastern,Indiana
5.9 litre 360 magnum v8
I'm thinking I'm eventually going to get a set of 17x9 5x5.5 bolt pattern us mag Indy "aluminum slot"wheels for my 2000 dodge ram 1500 probably with either a older but decent set of kumho road venture mt KL71 ,or Goodyear duratrac at tires,I had a set of the KL71 tires on my 86 Chevy k20 I liked them. Bit noisy but that's fine with me.
