Alright guys.. BILSTEINS post your pics!!!
BamaRam22
Alabama
I have a 2007 1500 4x4. I in the process of replacing the struts up front and have found what I thought was Bilstein struts but none I have seen was a complete assembly with the coil. I have a leveling kit on it. I am replacing the rear shocks with the Bilstein 5100 series.
Gordinho80
Monroe, NJ
2012 1500 Big Horn
From what I can tell, the Bilsteins don’t come with the cool spring already installed. You re-use your coil and upper mount. I could be mistaken, though. The adjustment is made by which position the lower perch is placed in.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
He's correct. You reuse the existing coil
Nandark
Waco, Texas
Outdoor76 I got the RC UCA's along with the Bilsteins. I love the look and the ride. Waiting for my tread to wear down and I'll go with bigger tires. Currently running Toyo Open Country AT 285/70R17. I posted a pic a few pages back on this thread.
TNram
Nashville
Just pulled in the shop, 275/65r20 KO2s and Bils at 2.1. Will post pictures when i get her back!
shadowhawk
Southeast WI
my comments may be all wrong though, since you have a 2007 Ram, not a gen4. do your research in the gen3 section.
Outdoors76
Rhode Island
What he said...
They do not come with coil. U need to compress coils and swap out your struts for the bilsteins
Outdoors76
Rhode Island
Cant wait for the uca's dammit lol
Did fender flares and oil catch can today
Still needs window tint steps for the wife and black vinyl rocker wrap.
TNram
Nashville
Alright guys, need some help. The tire shop said that the flange (probably not the roght terminology) on the existing strut is welded on and that even if it wasn’t, there is a cap on top of the strut that wouldn’t allow the flange to slide off. He said I should be able to order just the flange from ram. Anyone run into this? See attached...
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Mine just came off it was not welded and then slide over the flanged part.
TNram
Nashville
I figured they were being lazy. I’ll go somewhere else I guess
shadowhawk
Southeast WI
just take a small maul and tap it off- both of them. they aren't welded.
TheDonVon
Just did my front bils at 2.1 and had terra grappler 295/60R20s installed today. The tires are rubbing on the UCA, so it looks like i will need a small spacer to give me some clearance. Is it normal for UCA to be the area people experience rubbing? I was under the impression i would just have some rubbing on the wheel well liner? Wasn't expecting UCA clearance problems.
shadowhawk
Southeast WI
rub at full lock? I think I have a little of that, too, but I'm at 2.8
