SEALING 3RD BRAKE OPTIONS
ramportin1
Sickest member here
Oregon
BEFORE SOMEONE HITS ME WITH "SEARCH FUNCTION" lol I already have went through the many many threads and every one is for 4th gen 3rds and the back housing is different. I already bought that boat rubber gasket the one guy used and tried but it wont fit a 3rd gen its much to thick.
Im not a fan of silicone'n it or using gasket maker because if a bulb goes i dont wanna deal with that.
So does anyone know of a better option? Or maybe if that new 2018 or whatever gasket they finally switched to will work on a 3rd gen back? or maybe a better aftermarket one?
Nick@GotExhaust
Preferred Vendor
SC
I dont have a great option for you BUT the 1st Gen Raptors had an issue with the 3rd brake light leaking. I never had the issue but when I put LED's in there I figured I should do something to prevent it. When I had mine I actually used a left over electrical junction box gasket that I had and cut that to fit. It is a very thick but pliable gasket. It may not be the best option or easiest but it did work.
Did you use the SEARCH FUNCTION :crazy:
ramportin1
ramportin1
Sickest member here
Oregon
Thank man. If no-one has a great easy fix I will look at going this route and making one [emoji106] seems like it being such a famous issue someone out there woulda made a better direct replacement but I haven't been able to find one
Lil_Ram
Power tech 3.7L
What about a make your own sheet gasket thing. Most part stores sell the sheet cut it to fit then you have a gasket and no garbage later
ramportin1
ramportin1
Sickest member here
Oregon
Wonder if sink drain putty would work??
Now that's a unique idea, I bet you could use some kind of putty like that and work well
ramportin1
ramportin1
Sickest member here
Oregon
Think I'm just gunna find some kind of nice gasket material and cut my own, thanks for the responses guys!
RamCreeper
St Augustine, FL
I had a problem with the Brake light leaking on another truck. I took wax paper and taped it around the brake light then filled it with clear silicone and wiped of the excess. Let it dry for a few days and it sealed up perfectly. I haven't taken a look at my Dodge to see if I could do this yet but it worked great on the old truck.
xtremewlr
Tucson, AZ
Ingenious idea, thanks!
buddy guy
alberta
Did my preventative fix using MD brand Rubber weather stripping this morning on my 2018. it is a bugger scraping the oem foam off which indeed is quite thick and wide but its still foam at best which still concerns me. rather than using the 7/16 x 3/8 P type i think it is, I went a step bigger. i had taken the light in with me and while the height is right, the 3/8 is definitely narrow than the oem foam strip and that concerned me. the next size up was 1/4 x 5/8 and D type which is just fine I believe and was a perfect width compared to oem and a hair higher. i could screw down snugly and the screws are plenty long anyway. I was able to snug it down fine so that it was pretty much flush to my eye. Someone made a comment somewhere on the forums wondering if the rubber strip would stay flexible. The packaging says it's flexible from -40 to +140F so I'm very confident it will be fine. btw, where a person would cut the strips at the corners, I had a tube of GE marine silicone that I put on the corners to seal the strips there.
Spoonsize
Myrtle Beach, SC
T’were me I would go to my local embroidery supply fabric store and get a sheet of puffy foam larger than the light and cut out a gasket.
radikio
