HD Tire Pressure Monitoring System Reset
Status
Not open for further replies.
j2048b
cummins
Oops! That should have said 10-15 psi less in the rears. So 60 front & 50 rear would be a good start.
Hahah ok cool, i was hoping u meant that but had to check haha
Sent from my SM-G935V using Tapatalk
2ndA732
CA
Dang, I just saw that you have a 2018. The ECM is locked and that's were the TPMS settings are located. Keep watching this thread and I'll post when we have a fix.
x2 Another interested member for the '18 fix. Thanks for all the work on this! My dealer is not known for intelligence and customer care. but then again, i'm in ca.
4x4x4door
near St. Louis
Cummins 6.7
Is there anyone near Erie Pa that could do this for my 2017?
Sorry the closet guy is SW of Pittsburgh. I'll send 1 to you in the mail. I've helped tons of guys like yourself. Shoot me a PM if interested.
twelvexs
Hillsborough, NC
Cummins 6.7
Hey everyone. Like others, would like to lower the tire pressures on my 2014, but all 3 of my local dealers have said no go because of shop rules and government regulations.
To make matters worse, I bought my truck used and have no idea what the PIN is. Same 3 local dealers won't give that to me either, even with proof of ownership because I'm not 1) original owner or 2) didn't buy used from them.
Some searching the forum seems that I need a reader to pull the PIN-which I'm assuming is the same reader to reprogram the TPMS and the RFH.
Do I have any options here?
Thanks in advance for any help for a noobie to the HD RAM world.
BPMPVET
Cummins 6.7
Only a dealer can provide the PIN. It's on Deader Connect. There is no way to pull it off of the truck. There's people out there (including me) who will send you a device to do the process in your own driveway, but you've got to have the PIN...
twelvexs
Hillsborough, NC
Cummins 6.7
BPMPVET, thanks for your kind reply. I figured as much, so I'll head over to some other dealers in adjacent towns and hopefully have some more luck. Once I have it, sounds like there are options that will work out. Appreciate the response again!
loveracing1988
Clarkston, MI
If anyone is in the southeast Michigan area and needs this done I just figured out how to do it.
Sent from my LG-H918 using Tapatalk
4x4x4door
near St. Louis
Cummins 6.7
Figured it out as in you have an Autel or similar device?
loveracing1988
Clarkston, MI
Similar device. To quote I believe an Apple commercial. "there's an app for that"
Honestly it wasn't even my intention to change the tire pressures, I was just trying to add fog lights and figured I would try it to adjust thresholds and fog lights with hi beams and did it all in one shot.
goonbash
Banned
2016 2500 Longhorn Limited Megacab
cummins
Despite a dealership service manager saying it wouldn't work and saying if it did work it would reset with a battery disconnect, I just had my tpms values reset successfully.
Nando at Elite Auto in Costa Mesa did it. Pricey but he said a reprogram would be free if it ever reset for any reason. Been driving for a week with 55 psi rear no warnings or lights.
ripping r
Old&Grumpy
earth
6.4 HEMI
I need some one in AZ to do it for me. I dont care about the cost. just want the light out!
4x4x4door
near St. Louis
Cummins 6.7
Does this dealership sell AEV products?
goonbash
Banned
cummins
No idea, his home was closer to me than the business so we did it in his driveway.
Status
