grille lights
cody mummert
Pa
what leds are you guys using to make the 3 little amber or white led lights in the grill
JB1
Houston, Texas
I originally wired them to my fogs but I have them on a switch now. I basically bought a piece of Delrin (machinable plastic) and cut to fit the shape I wanted, then glued it to the factory grille insert using JB plastic weld, drilled a hole, mounted the LED and wired it up. Read the thread all the info should in there
cody mummert
cody mummert
Pa
im a dope i never even looked at the link lol my bad
Reactions: JB1
bmclark25
Saint Louis, MO
I got my LEDs from Superbright LEDs. I did pretty much the same as JB1 but used sheet metal and attached the bracket to the back of the grille.
bmclark25
Saint Louis, MO
I used a fuse tap and used it on the cigarette lighter fuse so that they come on when the truck is on.
muddy12
Indiana
Mine are wired to the passenger side marker light.
The wiring for the passenger side headlight runs along the back of the core support, and is easy to tap into.
