Overall nice setup. But something is off on those numbers. Heres why...
Your dyno numbers are all over the place, you have a bunch of pulls to 5350/5400 and they range from 430hp-515hp, unless these are in the tuning process, coming in slow or ramping up timing from a low number to be safe. But if the 515rwhp is accurate and the final number thats wayyy high. The supercharger requires power to make power (unlike a turbo) so if you calculate a 20-25% loss for drivetrain (big truck, big tranny, big DS and a large Dana rear) I would think 25% drivetrain loss would be accurate. Stock 5.7 hemi is 395hp, calculate +30hp with headers and TB. That gives you 425hp at the CRANK! Now minus 25% for drivetrain loss = (-106hp) 318rwhp. Thats your base number with the headers + TB. Boost will double your HP at 14-15psi (ideal), so at 6psi I would expect 40% increase which is pretty standard. 40% of 425 = 170hp so you could gain 170hp + 425hp base = 595hp. If you Still calculate the 25% loss (-149hp) your at 446rwhp... and that isn't even taking into account the HP that the blower is eating to make power. It would not be hard for that blower to eat 40-50hp at 6psi which brings down those numbers big time.
All I'm saying is that the math doesn't add up, 6psi is low boost, 40%-50% increase is good and even at 6psi the truck should feel like a whole new animal. If you were closer to 10-12psi I might believe the numbers as you would be close to doubling your power. Or if you had a car with a light drivetrain and a manual trans.
Either way Its a nice setup and you'll enjoy the boost/power... its addicting! No one ever stays at low boost for long. I ran 12psi on a centri which was fun but always had to worry about belt slip depending on how fast I got on it (rpm rise) and when the boost started lol. Now I turbo and at 14psi its a huge difference compared to 6psi, but I wouldnt do that in a 50k truck as my DD. One thing I always hated about blowers is the BOV streetsweeper noise... its just the worst!
