Are you wanting to add a powerful flush mount LED light set to your vehicle that looks like an OEM factory upgrade? Underground Lighting has a set with just that styling in mind with this powerful, 2" Square Flush Mount LED light set. Each Light has 6 spot LEDs and 2 Flood LEDs. You get the best of both worlds with a Spot/Flood combo. Each light is made with corrosion resistant, aluminum die-cast housings and feature 5W Philips LED lights. Excellent for use on any universal light mounting location, these lights work well with bull bars, light bars, brush guards, any any other aftermarket accessory.
Includes two, 2" LED square lights, mounting hardware, and a one year manufacturer warranty for quality assurance. Each light measures 4.80" x 3.11" x 3.63", contains eight Cree LEDs, and produces 4000 lumens of light.
https://undergroundlighting.com/products/40w-4000lm-flush-mount-cube-led-light
- OEM styling cues
- Each light measures 4.80" x 3.11" x 3.63"
- 8 5W Philips manufactured LED bulbs per light
- 40W 4000 lumens per light
- Works with any universal mounting location
- Available in black and chrome series LED lights
- Die-cast aluminum housing
- IP67 waterproof rating
- 2-Pc set includes all hardware
- 1-Year warranty
