First time 2006 Dodge Ram Laramie Owner
acolic
Hamilton
Hi,
a quick intro from a first time Dodge Ram owner.
Just picked up a nice rusty pickup (very cheap) for my son and I to repair. The bed, rocker panels and front fenders are pretty rusted out but the vehicle has potential.
I found a pretty decent bed which I am picking up tonight which after a bit of body work and a paint job is going to solve the rusty bed problem.
The rocker panels are going to be a bit challenging. I am having a bit of trouble finding a source for inner and outer replacement panels for a Crew Cab.
The front fenders seem to be pretty simple to fix, just a bolt on.
I had my mechanic go over the vehicle and the frame, motor, transmission, transaxle, diff etc look good.
I just need to fix the body and do a complete rear brake replacement before I can get it on the road.
The goal this year is to make it drivable and then next year we'll deal with lifting it etc. It will be mostly used to move my boat around, moderate offroading and long trips with the kids.
Alex
quietpeen
2021 TRX
Hellcat
welcome
MADDOG
Not RamForum Staff
Welcome to RamForum.
A
acolic
Hamilton
Step one is complete. I bought a mostly rust free bed.
The plan is to clean and prime the bed. There’s one small piece of rust to grind out and fix.
I’m thinking of spraying the bottom with bed liner to keep it from rusting.
ExpressRules
Southern New Jersey
2014 Express Crew Cab
Don't forget to post before pictures and more as each step of the work is completed. Welcome aboard.
A
acolic
Hamilton
Will do.
Posting will keep me motivated to get this job done.
It looks like I need to replace both the inner and outer rocker panels.
Anyone have any advice on how to remove the inner rocker panels?
A
acolic
Hamilton
It’s pulling out dents and repairing rust time.
It was my first time using a stud welder. Great tool.
The bottom half of two doors are rusted out I’ll have to figure that out.
chrisp2493
Always Modding
Warren, OH
392 Hemi
Will do.
Air chisel, pry bar, grinder and brute force. Been there, done that
I Bleed Ram Trucks
A
acolic
Hamilton
I have seen lower door patch panels available through RayBuck and others
What I don’t get is after I cut out and remove the lower part of the rusted door and I weld the patch panel on, how do I fold the edges?
Just a hammer or is there a special edge bending tool?
A
acolic
Hamilton
I guess there’s no going back.
I started work on replacing the rusty rocker panels and it looks like both the outer and inner need to be replaced.
It took quite a while to get to this point.
I need to step back and figure out how to cut out and replace the rusted inner section properly.
