Dash grime and cleanup
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Does anyone have any thoughts or products on how to clean the dash?
I have a 2014 1500 Express so it’s got the plastic dash. When I ran my hand across it earlier today it had a somewhat sticky texture and had little dust and fibers all over .... that I added to when I tried to dust off some with a microfiber towel.
Any suggestions are appreciated.
chrisbh17
Diluted woollite makes a quick easy and gentle interior cleaner.
If it's really bad you could use diluted all purpose cleaner but be careful to get one that isn't highly caustic (simple green is not good!)
Sent from my Nexus 6P using Tapatalk
kkreit01
Olathe, KS
Surf City Dash Away is my favorite. I've cleaned ink on light leather with it -- along with many other stains. It's my go-to interior cleaner/protectant.
Kinetic
Wipe it first with a towel wet with soapy water to cut the grime, then use a microfiber to apply something like Megs interior cleaner, either natural or glossy, up to you. I'd try the Megs first and if that doesn't cut the grime use the soapy wet towel first.
McBroom
Denison Tx
Hemi 6.4L
I do like Meguiar’s a lot!
I like the 303 the best for the interior. The whole interior.
Blue Streak Pearl off-road
Kinetic
I usually recommend Megs because it's readily available locally.
BTW, Are you using that exterior QD for the interior??
McBroom
Denison Tx
Hemi 6.4L
Oooopppppsssssss I posted the wrong picture. Sorry I didn’t notice that. My bad [emoji847]
GIJoe2010
GIJoe2010
Killeen, TX
Thanks, I appreciate your help. This is on my truck to do list this weekend (oil change, install light bar and bull bar, clean truck).
JB1
Houston, Texas
Your dash is sticky from whatever stuff you put on it before. Clean it real good with soap and water then use 303 Aerospace and nothing else from now on, it’ll protect your dash from UV and give it a nice look that won’t attract dirt/grime
I put this on my entire interior and exterior black plastics including tires, best stuff ever check reviews.
GIJoe2010
GIJoe2010
Killeen, TX
Is it locally available or via the interwebs?
kkreit01
Olathe, KS
My Napa carries 303. It's a great protectant, but doesn't clean well.
chrisbh17
I agree with suggesting things easily available. Meguiars Quick Interior Detailer is probably one of the best, I suggested diluted Woolite because it might be something someone already has.
If you are ordering products, Id look into Ultima Interior Shampoo Gel. My favorite interior cleaner by far, its just not available locally.
Kinetic
I'm pretty sure I've seen 303 at Autozone or Advanced Auto Parts
Schultzestrength
South Carolina
I clean it with Mr. Clean then protect it with 303. I usually clean it after 2 or 3 applications of 303. I just wipe it with a dry microfiber when needed otherwise.
Dark Knight 500
Alberta
X2
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
There are about half a dozen different 303 products so make sure you check the label for the right stuff. All the labels look similar.
Jay
