SOLD 2013 Premium Cluster SOLD
Status
Not open for further replies.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
So basically this SHOULD fit any 4th gen 2013 and up?
As far as I know it should. Only caveat I know of with 2013 and 2014 clusters is they do not have the aux switch configuration menu programming for 2015+ HD models. The aux switch configuration changed to the cluster in 2015 and prior year cluster do not have that. I ran into that problem with my 2015 HD Tradesman when I put in a then 2014 premium cluster. Had to sell it and find a 2015+ cluster for it.
LegionC1V
Tennessee
how would one adjust the mileage and idle/run hours for the new truck?
R.L.K.
R.L.K.
Bristol , Tn.
There's several places you can send it to . You just give them an ( as accurate as you can ) idle & hours and a mileage that gives you time to receive the cluster back , then drive to that exact milage and change the cluster then [emoji1303]
LegionC1V
Tennessee
I have a 2015, and there was some discussion earlier in this thread whether it may or may not work. Whats the conclusion there? allmoparparts have your part number as incompatible for a 15. really want to pull the trigger on this
R.L.K.
R.L.K.
Bristol , Tn.
To my knowledge the TPMS will only show dashes for the tire pressure .
Oddly in my 14 , this 13 cluster and the 16 cluster I have installed worked 100% in my truck
R.L.K.
R.L.K.
Bristol , Tn.
Still can't believe this has not sold yet
R.L.K.
R.L.K.
Bristol , Tn.
This Cluster is Sold .
Status
