Pop when accelerating from a stop
Zuf4
United States
When I accelerate from a stop I’m hearing a pop in the front end. I’ve only had the truck for about 2 months. 2004 1500 5.7L 4x4 quad cab only 92,000 miles
Any ideas?
kirbster
carolina
5.9 gas
my 03 1500 2wd w 276k has the same pop, new upper and lower ball joints, bushings, outer tie rods, sway bar links and calipers w brackets. and still pops. I have checked my drive shaft just in case the sound location was traveling or tricking me. but it still pops and I think it got worse when I replaced the calipers so I think it is the brake pads moving. but when the money and time rolls around again , I am gonna replace the rack & pinion, but the 4x4 front steering is set up different so I would check frt shaft ant ball joints first
