DodgeDude
new to the forum so if this is in the wrong section, feel free to move it.
I have a 1989 Dodge 150 with a 318, stick and 4wd. Evidently, I'm the only guy in the country who has this vehicle without a tilt wheel. And that's the issue.
I need a turn signal switch. AFAIK, the only switch for the non tilt wheel is the SMP DS-1218 and it is impossible to find.
I'm down to buying a used steering column to get the switch. But what if that's bad? Is there a work around for this, another switch that will work or am I just out of luck and I need to pay the 150 bucks for this used column and be done with it?
As it stands, I love the truck and I'll die with it. It checks off all my boxes so selling it is not an option.
Hopefully, the forum can help me out.
Thank you
Thank you
