AlfaOBD
SRich2015
USA
I found the terminals but can’t find any stock. S2072401 (smaller wires) S2038402 (larger wires). Maybe there are some that would work. I can try to look more later. Might be able to match up with another connector and get it at parts counter. I would guess they have some bulk terminal kits.
Are these the type of terminal you are talking about??
http://terminalsupplyco.com/Store/Product.aspx?pc=12047767
Jimmy07
We are looking for the BCM connector pins, not that one. They don't list any pins or repair kits for the BCM connector on that site.
@mtnrider
not sure if this helps any:
MODULE-BODY CONTROL C1/A
Harness Family: Body
Cavities: 26
Color:
Gender:
FEMALE
Part Description: 13850155_13850159
Engineering Name: Mod_CBC_CBC
Connector No: D3806A
Option: Standard
Ok, so we got that pin nailed down to this https://www.mouser.com/ProductDetail/829-13627884-L?r=829-13627884-L
Now I’m looking for pin 15 on the C4 connector (maybe the same?) http://connectors.dcctools.com/details.htm?id=215371
Pin 39 on the C5 connector http://connectors.dcctools.com/details.htm?id=215372
Pins 5, 25, and 28 on the C6 connector http://connectors.dcctools.com/details.htm?id=215373
Pins 3, 5, 14, 28, 29, and 30 on the front end connector http://connectors.dcctools.com/details.htm?id=215776
chrisbh17
MODULE-BODY CONTROL C4/D
Cavities: 29
Color:
Gender:
FEMALE
Part Description: 13850156_13850159
Connector No: D3806D
Option: Standard
MODULE-BODY CONTROL C5/E
Cavities: 26
Color:
Gender:
FEMALE
Part Description: 13850164_13850160_13850161
Connector No: D3806E
Option: Standard
MODULE-BODY CONTROL C6/F
Cavities: 21
Color:
Gender:
FEMALE
Part Description: 13850165_13850160_13850161
Connector No: D3806F
Option: Standard
NOTE: the pin part numbers for the above 3 connectors are supposedly the same...not sure if Im reading it wrong or if thats true, but this is the data they all seem to link to:
Terminal 1-4, 39-42: S2038402
Terminal 5-38, 43-48: S2072401
INLINE-BODY/FRONT END MODULE
Harness Family: Front_End_Module
Cavities: 34
Color:
Gender:
FEMALE
Part Description: 7283-9152-40
Engineering Name: Inline_I100_F
Connector No: I100_Front_End_Module
Option: Standard
bootlegfab
2016 Ram 2500 Tradesman
Cummins 6.7
So far this has been an amazing program...I've been able to activate tilt in reverse, VTA, fog lights with high beams, and am attempting DRL's. So far no luck tho...letting the truck sleep currently. I'm going to go back thru my initial log but off the top of my head I don't recall if "dedicated DRL light" is enabled or not.
I have:
DRL configuration : Optional DRL
DRL Lamp Location : Turn Signal DRL
DRL Dropout Enable : Yes
DRL Customer setting enable/disable : Yes
DRL customer settings menu : Set/Yes
I have Dedicated DRL lamp for both left/right set as no.
Moparman16
Northern Ontario
2013 Ram 1500
Are you talking aftermarket bulbs, a quad to projector swap, or ... ?
Try flipping the bulb over?
I have oem quad headlights with aftermarket switchback led bulbs in the turn/park position. Flipping the bulb doesn’t change anything.
Jimmy07
Cavities: 29
Color:
Gender:
FEMALE
Option: Standard
Cavities: 26
Color:
Gender:
FEMALE
Option: Standard
Cavities: 21
Color:
Gender:
FEMALE
Option: Standard
Cavities: 34
Color:
Gender:
FEMALE
Option: Standard
Thanks. I’ll see what I can find. Could you double check the front end connector http://connectors.dcctools.com/details.htm?id=215776
Those should be male pins (flat spade), and you’re description is showing female.
chrisbh17
Yeah I think I gave you the wrong side.
Cavities: 34
Color:
Gender:
MALE
Part Description: 7282-9152-40
Engineering Name: Inline_I100_M
Connector No: I100
Option: Standard
EDIT: its in this catalog somewhere: https://www.smdinc.com/pdf/yesc_yesc_kaizen_catalog.pdf
Ghost_RAM
Ghost_RAM
VA
I have:
You should be good to go with those settings. Just remember some settings seem to take longer for some.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
SRich2015
USA
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I have gotten a few connectors from them in the past but looking at what some of these other guys have posted after me they seem to have more!! Problem I see is that FCA uses their part # and these companies have their own so it takes a lot of research,looking and comparing and Hoping!!!
https://www.mouser.com/Aptiv/Connectors/Automotive-Connectors/_/N-1ehb5?P=1z0zlez
That's OK, I live in a town that has nothing but Walmart and Home Depot for 60 miles. But there is actually a Terminal Supply location 1.5 miles from me :party36::party36::party36:
kad
Hudson Valley, NY
5.7L HEMI
Hmm... The connector appears to be an Aptiv (formerly Delphi) 13673600. The two terminal sizes are 1.2mm and 2.8mm, but I haven't been able to get updated part numbers for the terminals yet. (The numbers given previously don't come up in their catalog) The Aptiv datasheet site pretty much sucks big hairy moose nose... If someone hasn't popped up with them by tomorrow I'll place some calls and see what I can find.
-K
Jimmy07
-K
Yeah, I can find the connectors all day long, but I can’t find anything on the terminals. The numbers chrisbh 17 posted are the numbers they have on their drawings, but when I search them, nothing comes up.
SRich2015
USA
If you have the part #'s for the Connectors then call Terminal Supply and they can give the part #'s for the terminals providing the connector # are Delphie(Aptiv).
http://terminalsupplyco.com/Store/Default.aspx?CAT=TERM060
4eyedconekiller
North MS
EcoDiesel
So, good news and bad news...
Good News:
Got connected! Read my truck's status, and cleared a few codes from installing LED bulbs in the tails/reverse lights.
Bad News: Every time I try to change something, I get the same error that I am showing in the attached screenshot - I've disconnected, restarted my computer, and reconnected. No change. What do I do?
SRich2015
USA
Good News:
I got that the first time I connected. But closed everything out and came back later and everything worked. Also noticed you are not running the latest version of the Alpha App. Try to update it....
4eyedconekiller
North MS
EcoDiesel
How would I update it? I'm running version 2.0.4.
UPDATE! I did get it to let me change some things! I was able to enable the front heated and ventilated seats, and the rear heated seats. Now, just to wait on the BCM to make the changes... I hate having to be patient, lol.
