Intense-Dakota
Landscape and Nature Photographer
- Joined
- Jul 11, 2016
- Posts
- 249
- Reaction score
- 105
- Location
- GUNTERSVILLE, Alabama
- Ram Year
- 2017
- Engine
- Hemi 5.7
I recently installed the Bilstein 5112 2in lift springs in the front along with 5100 series shocks all around. I have installed an adjustable track bar in the front also and everything is perfectly level and rides MUCH better for the most part. My next move is to raise the rear 1 inch. One thing that I am not real happy with though is the amount of small rebounds in the rear unless I run the tires (Falken A/T3W) down around 55-60 psi. This is the same as when i had the original shocks, but just a bit softer now. So, I have been looking at the Carli progressive rate 1in lift springs, but they are $400. I was wondering if standard Power Wagon springs would work, and also if they can, how are they different than standard 2500 springs (besides being 1 inch taller). I am not really worried about the 10-15% lower payload with the Carli springs as I rarely tow, and I don't think I will ever be loaded anywhere near the max payload of the truck. Usually it is just camping gear with the occasional load of wood.
