Hello all! Below is a list of known working codes when using AlfaOBD and the OBDLink MX Bluetooth with Android tablet/phone. This thread is to get the information out about this program/tool and its powerful interface. Ricks Ram, STecoD, Mpgrimm2 and I have been able to activate the following codes with no ill effect. I personally have been in contact with the developer several times and he is very willing to help and is pushing updates fairly regularly.
AlfaOBD is only available to Android and Windows platform. There is
NO iPhone support.
AlfaOBD
https://play.google.com/store/apps/details?id=com.AlfaOBD.AlfaOBD
https://www.amazon.com/ScanTool-426101-OBDLink-Bluetooth-Professional/dp/B006NZTZLQ
While there are other ways of connecting to your BCM with AlfaOBD, the above OBDII adapter has been tested and is preferred.
Before attempting any of this be sure to skim through the instructions/help pdf on getting started.
ANDROID
http://www.alfaobd.com/AlfaOBD_Android_Help.pdf
WINDOWS
http://alfaobd.com/AlfaOBD_Help.pdf
DeereGuy: In case anyone with a 2018 RAM would like to make changes to their truck, we have just officially announced a security bypass harness that will let alfaOBD and other tools work with the 2018s.
https://www.ramforum.com/threads/2018-ram-security-module-bypass.125133/#post-1801395
Please make notes for every code you set!!!
If there is a problem this will give you a starting point in which to go back and change what went wrong. We have found nothing in the codes listed below that is not reversible. While it is possible to select multiple codes at once, it is recommended to set one code at a time then let the truck sleep 3 to 5 minutes. When I first started this I noticed some of my codes didn't take right away. I believe it is because I was not giving it enough time.
Uploading System ID (BCM) Information: Thank you Mpgrimm2
To upload your System ID information (BCM) go to the "Tools" icon in the upper right corner. From there select "Upload to Google Drive", it will ask you to link to Google Drive. Link your Google Drive to Alfa. Select "Upload to Google Drive" and "Upload Faults and Status Log". Then select "Body_Chrysler_Info". Name the file to upload whatever you wish. Done! Now you can go to your Google Drive and read the system info a little easier.
For viewing the information directly on the app, go to the bottom and select the battery icon once a connection has been made. Then select Read System ID. It should start populating below. Form what I have seen the Alfa programming tool keeps a record by date of all changes in the BCM from time of first connection.
Known Working List This link provides a working list of codes that will be updated periodically with new additions.
Shared BCM Configurations
Index of How To's and info: Thank you to all those who have contributed!!!
Android getting started
Windows getting started
Tire size adjustments (Easy online calculator)
TPMS
Fob Programming Walk Through
Obtaining 4 digit pin from reluctant dealer
Differences on 4 and 5 digit pin code.
Mirror info for tilt in reverse function
Adding Rain Sense Wipers
Adding OEM Cargo Camera with M2Mods Harness
Do not use an app called SRTactivator. It could possibly leave your truck inoperable or at very least needing to have the BCM flashed at the dealer. It is strongly advised to not change the "Vehicle Line" or "Vehicle Brand". Be very careful in making changes to settings you are unsure of or that have not been tested.
FYI - AlfaOBD needs to be connected to your truck in order for you to be able to see all the settings. While most of them will show, you will not have several other as well as all the CSMs.
Ricks Ram: "I wanted to mention it might be a good idea for guys to leave positive comments in the Google Play Store or wherever you buy the alphaOBD tool from and mention that you're using it for your RAM so the developer will see how many of us who are using the tool are from the Ram community. I'm thinking it might help us in the future as he refines a tool when he knows how many guys are using it for Ram trucks since it was primarily used for Alfa Romeos and other cars prior to the Ram pickup.
I'll continue to update as I find new working codes or fixes to issues as given to me.
Special thanks out to Ricks Ram, STecoD and Mpgrimm2!! I don't believe I missed anything here but if I did, please let me know and I will edit. Thanks!
