Read through 4200+ posts in the last 2 days.... Where's my certificate of completion?
Got DRLs, Fogs with High Beams, Window Global Down, and AUX controls showing on the 8.4 screen so far with no issues.
Big thank you to everyone who has posted findings here. AlfaOBD is an outstanding tool.
Oops I missed one....Which AUX do you get displayed on your 8.4 screen?
Forgive me in advance if this has been asked and answered (yes, another one... ) but I'm waiting on my 4 digit pin (salesman is getting it for me tomorrow) and I've made some changes playing around and not knowing what I was doing:
Car configuration change: DRL customer setting enable/disable: ' NO ' -> '1 '
Car configuration change: LED License Lamps Present: ' NO ' -> '1 '
Car configuration change: DRL Lamp Location: ' FOG LAMP DRL ' -> '3 '
Car configuration change: DRL Configuration: ' OPTIONAL DRL ' -> '0 '
Car configuration change: DRL Configuration: ' NO DRL ' -> '3 '
Car configuration change: DRL Lamp Location: ' TURN SIGNAL DRL ' -> '4 '
Of course, I haven't "saved" anything yet without the PIN.
Is there a way to clear these body computer configuration changes and starting over from scratch? I'd like to not be as hap-hazard before going to the RFH and hitting "start."
Again -- sorry if asked and answered & Thanks!
-Guzzler
You dont need the pin to make these changes.
When saving to the RF-HUB doing a reset / replace?
M2mods is usually very good about returning messages and getting people set up. Not sure what would be going on there. Hopefully they will see your post and get a hold of you.Anyone tryed this cable on 18+ trucks to see if it will allow the use of AlfaOBD?
https://www.morris4x4center.com/aev-procal-bypass-harness-kit-for-2018-ram.html
I tryed contacting the guy selling his own cables on this forum multiple times with no response.
Yes you can enable the code for the power folding mirrors with the tool. I have done a few of them and they worked fine.Are we able to add power folding mirrors on a truck that had the option and that has the mirrors, switch, and modules yet? Not sure if the original post is being updated as you guys find new stuff. TIA
For the U1009, did you replace the rear view mirror, or mess around in the headliner at all?Truck has these two codes randomly. Anyone have any past experiences or thoughts resulting in the codes? Only reason I noticed is because I can't stop messing with the truck and I'm always looking through the Alpha app and checking for codes after the big mess I made with changes months ago. Also my vents under my middle seat center console do not blow any air on any HVAC setting. I seen someone said they did some kind of recalibration for their rear vents and it fixed their problem but I'm not sure if they were referring to the same vents and if so I cannot find under the Alpha app where to do the test.
