I know their hearts are in the right place but the EPA and state regulatory bodies just don't get it. Running that oily gas back into the intake does reburn some of the hydrocarbons but not all of it. Eventually that oil will create deposits inside the intake, on the valves, in the combustion chambers and then into the catalytic converters. Poor performance results, systems are damaged and since it can be an expensive fix, owners ignore it and the crud eventually finds its way to atmosphere. So what did we gain here, hmmmm???
OK...soap box put away...
Here's normal blowby in my SRT after 2K miles in colder weather and with me driving relatively sanely. (It's hard to keep my foot out of it... )
1K miles, cold weather, no racin':
Hotter weather and running hard (0W-40 full synthetic) means I'll have a 1/2 to 3/4 full catch can. Next time I dump it I'll measure the volume of the lower portion of the can. I called BT but the guy who answered the call had no idea what their 5.7L Ram truck catch can fluid capacity is.
Oh, and here's the BT one I have on the car now:
Interesting seeing all these threads on the catch cans, and it does seem like it could be a useful device. Unfortunately in California you can’t do anything to alter the emissions system. If you have one of those installed it won’t pass visual inspection during a smog check.
Moroso builds a catch can that uses a drain valve,you can put a hose on and drain into a catch basin,instead of having to unscrew the bottom half of the can to dump.
You could remove and replace be fore inspection.Interesting seeing all these threads on the catch cans, and it does seem like it could be a useful device. Unfortunately in California you can’t do anything to alter the emissions system. If you have one of those installed it won’t pass visual inspection during a smog check.
i plan to do this soon. these reports are proof of its importance. once one is installed how should one go about cleaning out whatever needs cleaning from that junk?
