fastf
- Joined
- Jul 8, 2017
- Posts
- 590
- Reaction score
- 230
- Location
- Georgia
- Ram Year
- 2005 Ram 1500 Quad Cab SLT Thunder road
- Engine
- 4.7
I believe in die electric grease as well as the next guy but darn.I had a coil pack go bad so I replaced the plugs and coil packs because it hasn't been done.Well when I pulled the coil pack on number 1 plug there was a ton of grease inside the boot.This wasn't the only coil pack full of the stuff if it wasn't for the nut on the intake manifold the coil pack would pop right out off the plug.Take in mind I wasn't the one who put the plugs in before I bought the truck.I believe in keeping things dry but if you get water on top of that engine that high you got problems.
