Derek Powers
Toying the idea of adding air bags to my 2016 2500 with coil suspension. Any companies or products better than others?
Yeah after much reading you’ll find it boils down to Air Lift 1000 vs Timber Grove. Thread after thread.I'm getting good feedback on timber grove and airlift from another source.
Airlift doesn't make the 1000s airbags for a 2500 which the OP is asking about.Yeah after much reading you’ll find it boils down to Air Lift 1000 vs Timber Grove.
I have the air lift 5000 in my 1500 didn’t have to cut or drill anything bolted right upUnfortunately TLC airbags are no longer around, they use a 6" Goodyear airbag. My buddy has them on his 2500 for towing his fifth wheel.
I heard many good things about Airlift and was considering them but their kit for the 1500 you had to cut the bump stop brackets(the TLC didn't). That is not the case for the 2500 install. Reason for leaning towards Airlift and TLC was the airbags physical diameter is larger, which means less pressure to lift the load(softer feeling ride). Couple Airlift's airbags with their WirelessOne compressor makes a great set up.
Airlift is also a Michigan company located in Lansing.
Your correct, I forgot about that. The 5000 Ultimate requires the bump stop to be cut, the regular 5000 ones do not.I have the air lift 5000 in my 1500 didn’t have to cut or drill anything bolted right up
I know the ones with the built in bump stop you had to cut the bumps stop cup off, thats why I didn't go with them. They were probably loosing business because of it and redesigned the mounting.I have Ultimate plus maybe the other way around regular 5000 might need cut
Well they must have redesigned bc I didn’t have to cut and I have built in bump stop I’ll take a picture tomoI know the ones with the built in bump stop you had to cut the bumps stop cup off, thats why I didn't go with them. They were probably loosing business because of it and redesigned the mounting.
