Aparator
I have some wiring issues with my 98 1/2 ton 5.2.
First the dash light shut down, then the running lights stopped working and now the brake lights cut out.
I dont know what I did to get the running lights back up so that isnt an issue, maybe i should replace the headlight switch?
I bought a new brake light switch and it caused the brake lights to work in reverse. Pedal in, lights off, pedal out lights on.
I've checked the filaments on the bulbs, they're all working. I rigged a ground from the switch to the frame and that didn't help.
On the switch connector, I only have power to the b+ line, should there be more?
Any other ideas I can try?
Any help is appreciated
