Olepainless
I've got 2014 Laramie 2500 6.7. The volume down button does not work at all. The volume up button works 50% of the time.
Everything else works.
Do you think that would be a clock spring issue? Bad volume switch (or need to clean the switch terminals)? Blown fuse?
