What is your tire pressure BF Goodrich all terrain ko2
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
I have found that the tire pressures that work the best are the ones posted by the vehicle manufacturer on the door jamb. There is no way that a pressure recommendation from a tire manufacturer is going to apply to hundreds of different trucks and SUV's with vastly different suspension characteristics and loads.
That sticker you’re referring to only applies to the OE tires they put on at the factory, or if you put on like-OE tires. For example, the Michelin Defenders I run are the pretty much the same exact class of tire as the Goodyear SRA’s, just worlds better but they were recommended by Michelin to run what the door sticker said.
A LT tire needs more pressure to support the same weight so, you can’t just use that sticker for that or you’ll put yourself at a dangerous risk.
ram1500rsm
Trabuco Canyon, CA
Tire load index rating of a tire is a numerical assigned value used to compare relative load carrying capabilities, the number varies with psi and it’s an industry standard so All manufacturers have to adhere more or less to same standards for weight handling.
In principle you want tires to be able to support your GVWR. So what’s a 4th gen Ram 1500 fully loaded GVWR? 6900lbs. GAWR at each axel is 3900lbs.
275/60/20 LT at 39psi tire is technically able to support 2072 lbs x 4 =8288 lbs. 1388lbs more than your GVWR and 244lbs than your GAWR. curb weight in this trucks is what 5500lbs for a full optioned crew cab 1500? And a crew cab 1500 is what 3241 lbs front with the Hemi, 2261lbs rear if you want to be more technical ? Your tires only need to be able to support 1620 lbs each in the front at a minimum, up to 3900lbs in the back fully loaded. Sure you'll have people exceeding the limits, and you have those who will never carry much weight.
A 275/70/20 at 35 psi is rated at 1920lbs carrying capacity. You do the math.
BFG wants to play by the books and will recommend at least 54-55 to match the 39psi load index rating of the same tire in p rated index at 2601lbs per FCA specs. When you call them the guy/lady is prob reading from their lawyers approved responses doesn’t mean is wrong though, Problem at 55 is that you’ll have a harsh ride if you don’t have a heavy loaded vehicle.
At 45psi for example that LT tire is able to support 2290lbs per corner or 9160lbs total.
Say you went bigger with a 20” tire say 35x12.5x20 LT, they'll say you want 50 psi to keep the factory load rating per the industry standard using the same 2600lbs per corner At 39psi FCA recommended. At 39 psi you’ll have 2267lbs support in each corner with the 35x12.5x20 LT tire. At 50 psi that will be 2680lbs, but she’ll ride harsh. In either case you’re exceeding your GVWR capacity.
One is matching factory specs, none will kill your truck. The same size at 35psi is able to support 2095lbs, same size at 25psi is rated at 1655lbs. Do the math.
Not all tires in LT will need this amount of psi, take a 37x12.5x17, you get 2150lbs at just 25psi, 2755lbs at 35psi.
Take a 315/70/17 LT tire 2535lbs at 35psi, 2655lbs at 39psi, 2915lbs at 45psi, again do the math.
You need to look at the placard to know your factory max load weight capacities. Manufacturer also included psi for those stressing about a number if you don’t want to hand calculate on your own and they have determined with that much psi you get max mpg and tire life with whatever tires they have included as factory options.
It doesn’t mean if you run less than 39 you’ll crash the moment your psi goes 1psi less than that. In stock trim your low pressure light comes at what 32psi, and I’d think they have to guess you’re loaded as to not exceed 6900lbs at least right?.... it doesn’t mean an LT tire at 39psi in the same size will be unsafe or not been able to carry max load because BFG told you to run 55 psi in this application. They’re matching factory load index specs. But you can do the math one more time and you'll know how many psi you need, is not rocket science.
My 10 Silverado 1500 crew cab 4x2 was rated from the factory at 6800lbs GVWR, 3650 GAWR front, 3950 GAWR rear, factory tires were P245/40/17 at 35psi. When you refer to the index table for a tire that size p rated that’s 2205 lbs per corner. 100lbs less advertised max mass compared to the RAM, yet can carry 50lbs more weight than my Ram in the back and still they gave us tires rated at almost 400lbs less per corner compared to what FCA said I should run in my RAM. I was running 35psi in that one with 285/70/17 E rated tires chalk tested, 2105lbs per corner, they exceeding my GVWR. I’m not running 35psi because the placard says so. you know your weight limits, you know the vehicle manufacturer recommendation as far as psi and you can use any psi combination along those lines as long as your choice supports your vehicle full gross vehicle weight rate, from there you can adjust for tire longevity, mpg and anything else that gives you happiness.
preachp
The Con State (CT)
Hi Op,
I have the 17's and I keep them at 55 empty and 65 loaded. Truck rides good and runs good at those pressures, but like I said I have 17's and E rating. Bfg says don't run them under 50 psi regularly as it will wear hard on the tires, OK for short periods but not for running all the time.
corneileous
Podunkyville, OK
I dunno, I read somewhere where someone said that just because these stock Goodyear’s are rated at 2601 pounds at 44 psi that when on a pickup, they’re not really rated for what the tire placard says but I dunno, I don’t know how true that is. At one point I’ve thought about lowering my pressures down to 36, what the recommended pressures were in my old 08 halfton which is pretty much the same as my new one.
First off, to be able to support that 2601 pounds as stamped on the sidewall of them Goodyear SRA’s, the tires need to be inflated to 44psi.
Second, maybe BFG is just being a little too careful with their pressure recommendation but look at the Ram Rebel; it runs a 17 inch LT tire that is supposedly set on the door placard to run 55 in the front and 45 in the back. That’s really not too far off from what BFG says to use in a 275/60/20.
Maybe the set I had woulda been fine at 45 all the way around, or even at 40, 39 but it wasn’t until those tires were inflated to 55 when they started to feel like a good-handling tire. At 39 they felt very spongy. Seemed like my stopping distance was increased, and you could hear the tread-blocks fighting for traction if you ever had to brake hard. Also my cornering sucked. At 55, that all changed but so did my ride quality. Ride quality still was questionable at 39 but it went from alright I suppose, to damn! Knocking my fillings loose!
For me, settling on 50 front, 45 back, seemed to be about as happiest of medium I was gonna find.
ram1500rsm
Trabuco Canyon, CA
The Fiasco with Firestone many years ago changed the industry safety levels. The load index P is reduced when mounted in a truck. Take the load index at any psi and divide that by 1.1 The load index standard is still the same number but reduced by the 1.1 factor when the tire is mounted in a pickup truck, crossover, suv, etc, etc as a safety precaution. All vehicle manufacturers here in the states have to abide by these rules and they have provisioned this in the placard already.
PJ Snyder
Grand Blanc MI
Hey guys I just picked up a new set of BF Goodrich all terrain ko2 tires for my 2014 Dodge Ram Sport
After I left the shop my tire pressure it's not exactly equal between all four tires and varies from 365 kPa to 370 which is between 50 and 51 pounds per square inch
Anyone have any guidance in terms of what recommended pressure you have your tires
I am noticing some slight vibration when traveling between 100 and 120 kilometers per hour
Sent from my SM-G950W using Tapatalk
PJ Snyder
Grand Blanc MI
I have always put in 50 lbs on my KO2's and get good mileage and handling with that pressure.
daveray9
I run mine around 54. They have 60k on them for miles and will probably go another 20 or so. I try to rotate every oil change so 6k usually. Stock size A/T ko2s
mfifield01
Hemi 5.7l
I've been running mine around 45 psi unloaded. I think this has been discussed before. Based on a previous thread, I lowered mine. I started with them high (55), but they ride rough. The truck felt jumpy over small bumps in the road. When towing, I have been running them at 52 psi.
Danny5
Surprise, Az
Cummins 6.7
I've run 45 unloaded before, and 50 while towing.
Now I am too lazy and just leave them at 50. :D
406shark
Minnesota
When you guys are talking about your tire pressures... are you talking cold, or after running them down the interstate at about 70 mph for 30 minutes?
Mine start at 42 or 43 cold depending on how cold the morning is. Once up to temp they run in the 45 - 47 psi range depending on outside temps. Today the high was only 71°, and they were at 47 psi after driving around town in mixed driving.
Jeff
TatertotScott
The man, the myth, the legend, the one and only!
La Center/Amboy, WA
Jeff
Cold. Always measure and change cold.
After driving you will always get variation.
Sent from my SM-G892A using Tapatalk
mfifield01
Hemi 5.7l
What are you towing? That's probably a good compromise. Anything about 50 starts to get rough.
