Rebuild?? or Replace?? 4.7
AaronDoesntCare
I have a 2005 dodge ram quad cab with the 4.7 I've had it for maybe 2 months and it just threw a rod and broke the piston in half the motor has 236,000ish miles on it from what I can tell(haven't really torn into it yet) only the rod and piston on the driverside rear cylinder and what I believe is the tone wheel appears to be damaged..
So should I replace the 4.7 or rebuild it? What would be the pros and cons of rebuilding vs replacing??
RoadRamblerNJ
Knoxville, TN
392 Hemi
Beware any hairline splits in the bore that are very hard to detect. Ask me how I know.
Fast69Mopar
If you are going to overhaul the 4.7, strip the engine down to the bare block and take it to your machine shop of choice and have them magnaflux the block to check for cracks. Its worth it to spend the money to vat the block and mangaflux it so that way you dont build a motor and have it come apart shortly after.
AaronDoesntCare
AaronDoesntCare
Thanks for all your tips and advice the truck is posted for sale while I'm slowly tearing down the motor to prepare for a rebuild if it's not bought by the time its put back together I'm ganna beef it up with a nice size cam for a nice weekend toy
HemiLonestar
MD
Thanks for all your tips and advice the truck is posted for sale while I'm slowly tearing down the motor to prepare for a rebuild if it's not bought by the time its put back together I'm ganna beef it up with a nice size cams for a nice weekend toy
Fixed it for you (you're gonna need two)
McBroom
Denison Tx
Hemi 6.4L
OP where in Texas are you located. I’m in Denison Texas
- The Blue Mule
amdwilsns01
