That's for the rear Park Sense sensorsWhat is this plug for? It is located on the driver side rear frame rail.
That’s the first thing I thought it was...right after posting. [emoji57]. Do you happen to know where the factory bed lighting plug (if equipped ) is?
I've seen it in 2016 and up 1500s.Cbrengman....from your signature looks like you have a 2014 1500? Then you do not have the factory bed lighting wiring. The bed lighting is present in ONLY 2500/3500 Rams 2016 and newer.
Gotcha. I miss understood.If it came with the option from the factory. If it did not come with the option and its a 1500 and has the wiring in place then you have found the FIRST 1500 with the wiring in place that did not have the option. There are numerous threads on this board and others with the same info that I posted. It also may have been added after, there is an OEM kit that has a wiring harness.
