PuffTheMagicDragon
Today was the first day in a long time I’ve had to work on the 06 Ram, so bear with me.
I managed to fix my driver’s side heated seat issue. (During the worst heat wave in years, go figure.) One of the pins in a connector under the seat had pushed out and was intermittent at first, but had finally lost connection all together. I pushed it back in and viola.
I then decided to wire up my passenger heated seat that I had been putting off until winter since i already had the dash and seat wiring apart and what not. Took the wiring that I snagged from a Pull a Part place and ran it down through the proper connectors and pin locations and got my Mrs. a warm butt too.
From there I pulled the heated seat pads off the pass side cause I’m currently working on swapping a power driver seat track under my passenger seat just for kicks and giggles, along with giving the Mrs. lumbar support for long drives. Got the power track from the donor heated seats i stole the butt warmers from lined up and the wiring squared away for that. Swapped the passenger seat back, legs, and adjustment hardware onto the driver power bits and now i just need to move over the cushions and covers and make a hole in them for the lumbar knob. Once i do all that i’ll put the warmers back in and swap the switch wiring around so the flipped switch works right.
I also used my OBDLink MX+ and AlfaOBD to turn on my accessory delay and turn on my fogs with my high beams. Nice little software.
I saw in there an option for Auto Headlights and that got me thinking. The Dakotas and Durangos got auto headlights, why not us...? So I flipped on the setting and it didn’t fry my PCM, so I’m hoping theres a way to make it work. I picked up an auto headlight switch and the 04-06 mopar sun sensor from one of the aforementioned vehicles from my local Pull a Part for $11 total and I plan to either make it all work or waste $1000 on a fried TIPM before all is said and done. The sunlight sensor on the Durangos and Dakotas (who use the very same headlight switch as our 06+ Rams) runs both input and output wires through the BCM instrument cluster. Our Rams have a whole bunch of unused pins on the back of our clusters... Hmmm... Its looking plausible. Unfortunately, when I hooked up the auto headlight switch and flipped it to the auto setting my headlights remained off. I was expecting them to automatically come on since I have no sensor hooked up yet. I figured it would default to on with no input from a light sensor. If anyone can confirm what happens to a 04-06 Durango’s auto headlights when the sensor is disconnected, that would be great. If they stay off like my truck did, then maybe I’ll look more seriously into getting this project working.
Finally, I cleaned all my junk out from the back seat and put my Husky floor liner back in. I had taken it out to clean it one day and cluttered up the floor before I had a chance to put it back. Funny how life goes sometime. Oh well.
If you made it this far in the post, then congratulations, you listen better than my wife. Hell, if you made it past the first paragraph even... lol.
Anyways, thanks for reading, and have a good one!
