Neil Derryberry
Hot glue and call it a day..
Yes. That's perfect for the sxm. Now to find the other one. This is exactly what NavRepair sends with radios that are missing the colored clips.Do y’all think something like this would work??
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/191769700041
Will these work?Yes. That's perfect for the sxm. Now to find the other one. This is exactly what NavRepair sends with radios that are missing the colored clips.
It's practically impossible to find the correct brand PCB mount connectors new so you can pull the colored piece off and use on a radio. I ordered several brands before I gave up.
M² Mods.
Trying again....
Pasting a link to Mouser is giving me issues...Trying again....
https://www.mouser.com/ProductDetail/Molex/73403-6290?qs=rJ%2BziJWpyswHdyUmysfYeg==
If you have a RA3 you get a HD radio. I will say it is so much better reception. It also operates quicker than the RA3. Finally you get the Apple CarPlay and AA capability.
I have a 2017 with the stock 8.4 NAV radio. I guess that is RA 3. I have a back up camera. I never use Uconnect. I think I read back in the middle of this thread that the navigation has problems communicating with the cluster? And that u connect doesn’t work? I have an iPhone, with Apple Music and listen to it almost exclusively. The Apple
CarPlay would be the main feature that I would like to have. Would like to be able to get album art on Apple CarPlay through Apple Music.
The NAV in the UAQ has worked flawlessly so far. The thread does say you can not get over the air software updates.
P.S. the NAV works in the cluster on my 2017 as well as backup and cargo cameras.
I do know that they offer map updates for the RA3 online. I hope this is possible for the UAQ in the future.
The display issue mainly showed up on 13-15 clusters with some of the UAQ's sxm stations not displaying title names across the top of the evic and some of the turn by turn directions (UAQ) not displaying correctly. I don't think this will be an issue on a 16+ truck/evic.I have a 2017 with the stock 8.4 NAV radio. I guess that is RA 3. I have a back up camera. I never use Uconnect. I think I read back in the middle of this thread that the navigation has problems communicating with the cluster? And that u connect doesn’t work? I have an iPhone, with Apple Music and listen to it almost exclusively. The Apple CarPlay would be the main feature that I would like to have. Would like to be able to get album art on Apple CarPlay through Apple Music.
If your 17 truck has dual zone ATC ? then you most likely only need the 18 ram PN UAx radio, one of the compatible 2018 USB hubs listed and the hub adapter harness we offer.
If you don't have ATC, you 'may' get away with only swappping out the HVAC module for the 2018 version but there's a better than 50/50 chance you will need to add ATC to get the HVAC blend doors to work correctly to give full hot/cold.
M² Mods.
