Thuren fox shocks vs bilstein 5100
Nickx86
NJ
opinions on these two shocks for the rear of my ram 2500 w factory coils.
I’m not looking to get a softer spring since I load up my truck pretty regularly and i didn’t want the headache of air bags and extra expense
Most of my driving is on road w some occasional off roading that is slower speeds.
SouthTexan
408 CTD
Without the softer coils, you will probably not feel much of a difference between these shocks. The factory coils are pretty stiff and come into play really early so the shock don't have much of a dampening effect. I would recommend a a Sumosprings Rebel blue kit(not the black). It made a significant difference dampening the bumps both unloaded and loaded. There is also less squat when loaded, and their two piece design allows for articulation when I go off road at the farm and deer lease.
MN-Ram
MN
6.4L Hemi
I put Bilstein 5100’s in my 3500. The stiffness of bumps remain the same, but the “aftershocks” are better, if that makes any sense.
There’s no shaking after a bump anymore. It just returns to level after a bump.
Nickx86
Nickx86
NJ
That does make sense cause that’s what I’m trying to eliminate, I’ll never expect the truck to ride like a 1/2 ton, even though this 3/4 ton rides better than some 1/2 tons w an aluminum body that have Real truck tires and not some whimpy passengers tires.
SouthTexas, you wouldn’t happen to have a picture of what they look like installed, the sumo springs, they are intriguing to me?
Ratket
Arizona-
Here, watch this and inquire with Carli and see what they say.
SouthTexan
408 CTD
Although you probably won't need to, you can remove the bottom cushion(only 1 one bolt) on both sides in less than 10 minutes and can even do it without a jack out in the field if you have a way to articulate one side of the axle. These pictures were taken on install. I was not on level ground with the front of the facing downward so there is a little more separation than there is on level ground. They also sell .5, 1, and 2 inch spacer kits if needed for lifted trucks.
Driver Front
Driver Rear
Passenger Front
Passenger Rear
Nickx86
Nickx86
NJ
Perfect, thanks southtexan
