2012Lamarie
- Joined
- Mar 7, 2017
- Posts
- 228
- Reaction score
- 71
- Ram Year
- 2012
- Engine
- 5.7 Hemi
Thanks. What about the rear of the front wheel well? Will my -44 the rear has less room that the front.You'll need to cut the front plastic bumper to fit 37's
This was before trimming for 37's.
I had 35x12.5r20 but my wheels are 20x10 -24mm offset.
Cool thanks. Already ground the pinch weld down when I first got the rims before the lift so I'm good there. Thanks for your help man. Going to go with the 37's as soon as my 35's are worn out. And my wife forgets about the 5k I just spent on the lift, rims and other things lol.The rear cleared without having to modify anything. You might have to grind in the pinch weld though. I'll have to snap a couple pics to show how close it gets.
Sounds like your ready to take the first step...into Mods anonymous. We have a really big group here at Ramforum, be we also have a lot of our guys that relapse often. Just keep coming back!Cool thanks. Already ground the pinch weld down when I first got the rims before the lift so I'm good there. Thanks for your help man. Going to go with the 37's as soon as my 35's are worn out. And my wife forgets about the 5k I just spent on the lift, rims and other things lol.
Just curious what MPG are you getting?
And that’s what keeps me from taking the plunge on 37’s!!!!!I did the same thing. Purchased 35's first thinking I would be good. Got almost 60k out of my G2's. I didn't expect the tires to lift the truck as much as it did. From worn out 35's probably closer to 34's to big ole 37's the truck lifted up an 1.5"s. I can't fit it in the garage anymore.
7' garage door opening
I’ve done the same, heck I even had a guy come out to see what it would take to convert the 2 singles doors to a double..............I’ve “kissed” the molding a time or 2 with my tow mirrors.We've been looking at how to cut for a larger door
