1950 Dodge pickup rebuild
RAMWags
North Dakota
HEMI 5.7
I am starting a rebuild of a 1950 Dodge pickup and I am looking for advice on what engine to put in it. Anyone have any suggestions? Anyone know what engines fit without to many alterations? Thanks in advance.
ramportin1
Sickest member here
Oregon
Please do a rebuild thread, I'd like to follow along [emoji1689]
Sent from my SM-G975U using Tapatalk
ramportin1
Sickest member here
Oregon
And I vote 5.7 hemi [emoji23]
Shaggy
Administrator/Owner
Administrator
Start up a build thread. Post pics of the truck and your plans. There will be a ton of members that will love to watch this build and also will help you out with ideas.
Ernesto Pizarro
Nassau county, FL
Years ago I built a 49 Dodge B1B (1/2 ton) Panel Truck. I used a Fatman Fabrications Mustang II based frontend kit and installed a 1970 340 cu in with an A518 RH overdrive transmission. Everything fit nicely. Used an 8 3/4" rear as well.
avantiguy
Bay City, Mi
hemi
Have you considered using a Dodge Dakota chassis under it. You would have all the modern underpinnings, modern power, steering and stopping power. A lot of folks have put S-10 chassis under old pickups and the Dakota's are probably about the same size.
ACJCF2
Port Royal, SC
2018 3500 Tradesman CC DRW 4X4
Cummins 6.7L (408 cid) TD
Join the P-15/D-24 forum. They have a truck section. Good people.
